Gerade verzahnt/schräg verzahnt
Zahnradmaus
Postby Zahnradmaus » Fri Apr 26, 2019 10:23 am
Hallo Freunde,
kann man schrägverzahnte mit geradverzahnten Zahnrädern paaren, ohne dass es zu Problemen kommt?
Gibt es eine Software, mit der ich das simulieren kann?
In meinem Getriebe sind M0,2 gerade verzahnte Zahnräder (Kopfkreisdurchm. 4mm, 18 Zähne) eingebaut.
Da ich ein Zwischenrad verloren habe suche ich einen Ersatz.
Günstig und kurzfristig kann ich ein schrägverzahntes Zahnrad bekommen.
Gruß und vorab vielen Dank
Zahnradmaus
wandererfan
Re: Gerade verzahnt/schräg verzahnt
Postby wandererfan » Fri Apr 26, 2019 11:56 am
Translation by Google:
Hello friends,
Is it possible to mate helical gears with straight sprockets without causing problems?
Is there any software that I can use to simulate this?
In my gear M0,2 straight toothed gears (head circle diameter 4mm, 18 teeth) are installed.
Since I've lost an idler I'm looking for a replacement.
Cheap and short term I can get a helical gear.
Greetings and thanks in advance
gear mouse
Postby chrisb » Fri Apr 26, 2019 12:37 pm
Moved to Help forum.
You cannot just replace a straight toothed gear in a gearbox by a helical gear. Both types can be paired of the axes are positioned in the appropriate angle as well, but not if they are supposed to be parallel.
NormandC
Postby NormandC » Fri Apr 26, 2019 12:56 pm
Chris, come on. Again? German. :roll:
Postby chrisb » Fri Apr 26, 2019 3:55 pm
This time I had seen it, but as wandererfan gave already a translation I had left it here. And now I'm in some kind of undefined state and don't know what to do :( .
openBrain
Postby openBrain » Fri Apr 26, 2019 5:38 pm
IMHO there are 2 questions :
  • Is the OP able to read answers written in english ? If not, what is done here has no sense for him/her. In that case better keep it in the german subforum. ;)
  • Is that acceptable that the thread title is not in english (regarding the body, it's acceptable for me to get a translation) ? If the OP wants to keep its topic here, I think he should at least translate this.
My 2 cents :P
Postby chrisb » Fri Apr 26, 2019 9:08 pm
Verschoben ins deutsche Forum.
Kannst Du die englische Antwort oben verstehen?
r.tec
Postby r.tec » Sat Apr 27, 2019 8:45 am
https://www.kisssoft.ch/deutsch/home/index.php <- da gibts irgendwo eine Demo-Version
Postby chrisb » Sat Apr 27, 2019 9:03 am
Wenn Du nur ein geradverzanhtes Zahnrad gegen ein schrägverzahntes austauschen wills, dann wird das nicht gehen, bestenfalls machst Du die Zahnräder kaputt, schlimmstenfalls auch noch Wellen und Gehäuse. Stell' Dir ein geradeverzahntes Rad vor und Du schaust direkt auf die Zähne. Wenn Du nun ein schrägverzahntes drauflegst, dann kreuzen sich die Zähne und greifen nicht ineinander.
Wenn Du beide Zahnräder austauschst, dann geht das im Prinzip, allerdings erzeugst Du dann Axialkräfte auf der Welle. Um die aufzufangen kannst Du ein doppeltschrägverzahntes Rad nehmen (der Citroen-Doppelwinkel hat da seinen Ursprung) oder Du musst die Wellen mit Schräg- oder zusätzlichen Axiallagern ausstatten.
Die dritte der beiden Möglichkeiten ist, dass Du dich einfach nicht um die Axialkräfte scherst.
freecad-heini-1
Postby freecad-heini-1 » Sat Apr 27, 2019 3:12 pm
Hallo Freunde,
Zahnradmaus
Bitte beschreibe das Zwischenrad sehr genau.
