FreeCAD startet nicht
wondalfo
Post by wondalfo »
Hallo zusammen,
nach der Installation auf meinem alten Laptop (Win 10, 64Bit) startet FreeCAD nicht.
Aus einem anderen Thema heraus, habe ich gelesen, dass man das Logfile posten soll.
Ihr findet es daher hier (Teil 1):
Msg: FreeCAD 0.19, Libs: 0.19R24291 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2021
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
Log: Time = Mon Jul 26 12:11:40 2021
Log: AppDataSkipVendor = true
Log: AppHomePath = C:/Program Files/FreeCAD 0.19/
Log: AppIcon = freecad
Log: AppTempPath = C:\Users\WOLFGA~1\AppData\Local\Temp\
Log: BinPath = C:/Program Files/FreeCAD 0.19/bin\
Log: BuildRepositoryURL = git://github.com/FreeCAD/FreeCAD.git releases/FreeCAD-0-19
Log: BuildRevision = 24291 (Git)
Log: BuildRevisionBranch = releases/FreeCAD-0-19
Log: BuildRevisionDate = 2021/04/15 09:17:08
Log: BuildRevisionHash = 7b5e18a0759de778b74d3a5c17eba9cb815035ac
Log: BuildVersionMajor = 0
Log: BuildVersionMinor = 19
Log: Console = 0
Log: CopyrightInfo = © Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2021
Log: Debug = 0
Log: DocPath = C:/Program Files/FreeCAD 0.19/doc\
Log: ExeName = FreeCAD
Log: ExeVendor = FreeCAD
Log: ExeVersion = 0.19
Log: LoggingConsole = 1
Log: LoggingFile = 1
Log: LoggingFileName = C:\Users\Wolfgang Staroske\AppData\Roaming\FreeCAD\FreeCAD.log
Log: MaintainerUrl = http://www.freecadweb.org/wiki/Main_Page
Log: PATH = C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Users\Wolfgang Staroske\AppData\Local\Microsoft\WindowsApps;
Log: PythonSearchPath = C:\Program Files\FreeCAD 0.19\bin\python38.zip;C:\Program Files\FreeCAD 0.19\bin\DLLs;C:\Program Files\FreeCAD 0.19\bin\lib;C:\Program Files\FreeCAD 0.19\bin
Log: RunMode = Gui
Log: SplashAlignment = Bottom|Left
Log: SplashInfoColor = #c8c8c8
Log: SplashScreen = freecadsplash
Log: SplashTextColor = #ffffff
Log: StartWorkbench = StartWorkbench
Log: SystemParameter = C:\Users\Wolfgang Staroske\AppData\Roaming\FreeCAD\system.cfg
Log: UserAppData = C:\Users\Wolfgang Staroske\AppData\Roaming\FreeCAD\
Log: UserHomePath = C:\Users\Wolfgang Staroske\Documents
Log: UserParameter = C:\Users\Wolfgang Staroske\AppData\Roaming\FreeCAD\user.cfg
Log: Verbose =
Log: Create Application
Log: Run App init script
Log: Init: starting App::FreeCADInit.py
Log: Init:   Searching for modules...
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\AddonManager... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Arch... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Draft... done
Log: Drawing became obsolete in 0.17; consider using TechDraw instead.
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Drawing... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Fem... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Idf... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Image... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Import... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Inspection... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Material... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Measure... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Mesh... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\MeshPart... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\OpenSCAD... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Part... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\PartDesign... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Path... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Points... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Raytracing... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\ReverseEngineering... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Robot... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Show(Init.py not found)... ignore
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Sketcher... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Spreadsheet... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Start... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Surface... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\TechDraw... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Test... done
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Tux(Init.py not found)... ignore
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Web... done
Log: Using C:\Program Files\FreeCAD 0.19\Mod as module path!
Log: System path after init:
Log:    C:\Program Files\FreeCAD 0.19\bin
Log:    C:\Program Files\FreeCAD 0.19\Mod\AddonManager
Log:    C:\Program Files\FreeCAD 0.19\Mod\Arch
Log:    C:\Program Files\FreeCAD 0.19\Mod\Draft
Log:    C:\Program Files\FreeCAD 0.19\Mod\Drawing
Log:    C:\Program Files\FreeCAD 0.19\Mod\Fem
Log:    C:\Program Files\FreeCAD 0.19\Mod\Idf
Log:    C:\Program Files\FreeCAD 0.19\Mod\Image
Log:    C:\Program Files\FreeCAD 0.19\Mod\Import
Log:    C:\Program Files\FreeCAD 0.19\Mod\Inspection
Log:    C:\Program Files\FreeCAD 0.19\Mod\Material
Log:    C:\Program Files\FreeCAD 0.19\Mod\Measure
Log:    C:\Program Files\FreeCAD 0.19\Mod\Mesh
Log:    C:\Program Files\FreeCAD 0.19\Mod\MeshPart
Log:    C:\Program Files\FreeCAD 0.19\Mod\OpenSCAD
Log:    C:\Program Files\FreeCAD 0.19\Mod\Part
Log:    C:\Program Files\FreeCAD 0.19\Mod\PartDesign
Log:    C:\Program Files\FreeCAD 0.19\Mod\Path
Log:    C:\Program Files\FreeCAD 0.19\Mod\Points
Log:    C:\Program Files\FreeCAD 0.19\Mod\Raytracing
Log:    C:\Program Files\FreeCAD 0.19\Mod\ReverseEngineering
Log:    C:\Program Files\FreeCAD 0.19\Mod\Robot
Log:    C:\Program Files\FreeCAD 0.19\Mod\Show
Log:    C:\Program Files\FreeCAD 0.19\Mod\Sketcher
Log:    C:\Program Files\FreeCAD 0.19\Mod\Spreadsheet
Log:    C:\Program Files\FreeCAD 0.19\Mod\Start
Log:    C:\Program Files\FreeCAD 0.19\Mod\Surface
Log:    C:\Program Files\FreeCAD 0.19\Mod\TechDraw
Log:    C:\Program Files\FreeCAD 0.19\Mod\Test
Log:    C:\Program Files\FreeCAD 0.19\Mod\Tux
Log:    C:\Program Files\FreeCAD 0.19\Mod\Web
Log:    C:\WINDOWS\system32
Log:    C:\WINDOWS
Log:    C:\WINDOWS\System32\Wbem
Log:    C:\WINDOWS\System32\WindowsPowerShell\v1.0\
Log:    C:\WINDOWS\System32\OpenSSH\
Log:    C:\Users\Wolfgang Staroske\AppData\Local\Microsoft\WindowsApps
Log:
Log: Init: App::FreeCADInit.py done
Log: Init: Creating Gui::Application and QApplication
Log: Local server 'FreeCAD' started
Log: This system does not support framebuffer objects
Log: This system does not support NPOT textures
Log: OpenGL version is: 1.1 (1.1.0)
Log: Run Gui init script
Log: Init: Running FreeCADGuiInit.py start script...
Log: Init:   Searching modules...
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Idf(InitGui.py not found)... ignore
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Measure(InitGui.py not found)... ignore
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Show(InitGui.py not found)... ignore
Log: Init:      Initializing C:\Program Files\FreeCAD 0.19\Mod\Tux... done
Log: Init: Loading FreeCAD GUI
Log: Init: Running FreeCADGuiInit.py start script... done
Log: Init: Activating default workbench StartWorkbench
Log: Loading GUI of Web module... done
Log: Loading GUI of Start module... done
Log: Loading Start module... done
Log: Id: 6376: SymInit: Symbol-SearchPath: '.;C:\Program Files\FreeCAD 0.19\bin;C:\Program Files\FreeCAD 0.19\bin;C:\WINDOWS;C:\WINDOWS\system32;SRV*C:\websymbols*http://msdl.microsoft.com/download/symbols;', symOptions: 530, UserName: 'Wolfgang Staroske'
Log: Id: 6376: OS-Version: 6.2.9200 () 0x100-0x1
Log: Id: 6376: C:\Program Files\FreeCAD 0.19\bin\FreeCAD.exe:FreeCAD.exe (00007FF68A310000), size: 147456 (result: 0), SymType: '-nosymbols-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\FreeCAD.exe', fileVersion: 0.19.0.16100
Log: Id: 6376: C:\WINDOWS\SYSTEM32\ntdll.dll:ntdll.dll (00007FFC40B50000), size: 2052096 (result: 0), SymType: '-exported-', PDB: 'C:\WINDOWS\SYSTEM32\ntdll.dll', fileVersion: 6.2.19041.1110
Log: Id: 6376: C:\WINDOWS\System32\KERNEL32.DLL:KERNEL32.DLL (00007FFC3F6E0000), size: 774144 (result: 0), SymType: '-exported-', PDB: 'C:\WINDOWS\System32\KERNEL32.DLL', fileVersion: 6.2.19041.1023
Log: Id: 6376: C:\WINDOWS\System32\KERNELBASE.dll:KERNELBASE.dll (00007FFC3E540000), size: 2920448 (result: 0), SymType: '-exported-', PDB: 'C:\WINDOWS\System32\KERNELBASE.dll', fileVersion: 6.2.19041.1110
Log: Id: 6376: C:\WINDOWS\System32\ucrtbase.dll:ucrtbase.dll (00007FFC3E810000), size: 1048576 (result: 0), SymType: '-exported-', PDB: 'C:\WINDOWS\System32\ucrtbase.dll', fileVersion: 6.2.19041.789
Log: Id: 6376: C:\WINDOWS\System32\SHELL32.dll:SHELL32.dll (00007FFC3FE10000), size: 7598080 (result: 0), SymType: '-exported-', PDB: 'C:\WINDOWS\System32\SHELL32.dll', fileVersion: 6.2.19041.1023
Log: Id: 6376: C:\WINDOWS\System32\msvcp_win.dll:msvcp_win.dll (00007FFC3E450000), size: 643072 (result: 0), SymType: '-exported-', PDB: 'C:\WINDOWS\System32\msvcp_win.dll', fileVersion: 6.2.19041.789
Log: Id: 6376: C:\WINDOWS\System32\USER32.dll:USER32.dll (00007FFC3F7B0000), size: 1703936 (result: 0), SymType: '-exported-', PDB: 'C:\WINDOWS\System32\USER32.dll', fileVersion: 6.2.19041.906
Log: Id: 6376: C:\Program Files\FreeCAD 0.19\bin\FreeCADGui.dll:FreeCADGui.dll (00007FFC045E0000), size: 12529664 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\FreeCADGui.dll'
Log: Id: 6376: C:\WINDOWS\System32\win32u.dll:win32u.dll (00007FFC3EB90000), size: 139264 (result: 0), SymType: '-exported-', PDB: 'C:\WINDOWS\System32\win32u.dll', fileVersion: 6.2.19041.1110
Log: Id: 6376: C:\WINDOWS\System32\GDI32.dll:GDI32.dll (00007FFC3ED80000), size: 172032 (result: 0), SymType: '-exported-', PDB: 'C:\WINDOWS\System32\GDI32.dll', fileVersion: 6.2.19041.746
Log: Id: 6376: C:\WINDOWS\System32\gdi32full.dll:gdi32full.dll (00007FFC3E340000), size: 1093632 (result: 0), SymType: '-exported-', PDB: 'C:\WINDOWS\System32\gdi32full.dll', fileVersion: 6.2.19041.1110
Log: Id: 6376: C:\WINDOWS\System32\ADVAPI32.dll:ADVAPI32.dll (00007FFC3F5D0000), size: 704512 (result: 0), SymType: '-exported-', PDB: 'C:\WINDOWS\System32\ADVAPI32.dll', fileVersion: 6.2.19041.1052
Log: Id: 6376: C:\WINDOWS\System32\msvcrt.dll:msvcrt.dll (00007FFC40A70000), size: 647168 (result: 0), SymType: '-exported-', PDB: 'C:\WINDOWS\System32\msvcrt.dll', fileVersion: 7.0.19041.546
Log: Id: 6376: C:\WINDOWS\System32\sechost.dll:sechost.dll (00007FFC3EBC0000), size: 634880 (result: 0), SymType: '-exported-', PDB: 'C:\WINDOWS\System32\sechost.dll', fileVersion: 6.2.19041.906
Log: Id: 6376: C:\WINDOWS\System32\RPCRT4.dll:RPCRT4.dll (00007FFC3FCE0000), size: 1220608 (result: 0), SymType: '-exported-', PDB: 'C:\WINDOWS\System32\RPCRT4.dll', fileVersion: 6.2.19041.1081
Log: Id: 6376: C:\Program Files\FreeCAD 0.19\bin\FreeCADBase.dll:FreeCADBase.dll (00007FFC12590000), size: 1273856 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\FreeCADBase.dll'
Log: Id: 6376: C:\Program Files\FreeCAD 0.19\bin\MSVCP140.dll:MSVCP140.dll (00007FFC18750000), size: 577536 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\MSVCP140.dll', fileVersion: 14.28.29910.0
Log: Id: 6376: C:\Program Files\FreeCAD 0.19\bin\VCRUNTIME140.dll:VCRUNTIME140.dll (00007FFC37630000), size: 106496 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\VCRUNTIME140.dll', fileVersion: 14.28.29910.0
Log: Id: 6376: C:\Program Files\FreeCAD 0.19\bin\VCRUNTIME140_1.dll:VCRUNTIME140_1.dll (00007FFC37620000), size: 49152 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\VCRUNTIME140_1.dll', fileVersion: 14.28.29910.0
Log: Id: 6376: C:\Program Files\FreeCAD 0.19\bin\FreeCADApp.dll:FreeCADApp.dll (00007FFC03EB0000), size: 3092480 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\FreeCADApp.dll'
Log: Id: 6376: C:\Program Files\FreeCAD 0.19\bin\Qt5Widgets.dll:Qt5Widgets.dll (00007FFC03960000), size: 5509120 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Qt5Widgets.dll', fileVersion: 5.15.2.0
Log: Init: Showing main window
Log: Main window restored
Log: Id: 6376: C:\Program Files\FreeCAD 0.19\bin\Qt5Gui.dll:Qt5Gui.dll (00007FFC032A0000), size: 7057408 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Qt5Gui.dll', fileVersion: 5.15.2.0
Log: Id: 6376: C:\WINDOWS\System32\ole32.dll:ole32.dll (00007FFC3F9B0000), size: 1220608 (result: 0), SymType: '-exported-', PDB: 'C:\WINDOWS\System32\ole32.dll', fileVersion: 6.2.19041.746
Log: Id: 6376: C:\WINDOWS\System32\combase.dll:combase.dll (00007FFC40560000), size: 3493888 (result: 0), SymType: '-exported-', PDB: 'C:\WINDOWS\System32\combase.dll', fileVersion: 6.2.19041.1081
Log: Id: 6376: C:\Program Files\FreeCAD 0.19\bin\Qt5Core.dll:Qt5Core.dll (00007FFC02CD0000), size: 6053888 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Qt5Core.dll', fileVersion: 5.15.2.0
Err: Illegal storage access...
Err: Unhandled Base::Exception caught in GUIApplication::notify.
The error message is: Illegal storage access! Please save your work under a new file name and restart the application!
Log: The event type 14 was sent to QtWebEngineCore::RenderWidgetHostViewQtDelegateWidget
Habt ihr eine Idee was das Problem ist?
Vielen Dank schonmal Wolfgang
Re: FreeCAD startet nicht
Sieht mir nach einem PRoblem mit der Grafikkarte bzw. dem Treiber aus. Schau mal in den Known OS specific issues.
