Sketcher shortcuts…
rynn
Sketcher shortcuts…
Post by rynn »
Hallo,
scheinbar haben sich die Sketcher shortcuts geändert. git commit 0926a4148bcff11249fd4f56bc30256102ffe105
Den Unterschied zwischen
Sketcher_CompConstrainRadDia / Constrain arc or circle (shortcut: R ) und
Sketcher_ConstrainRadiam / Constrain auto radius/diameter (shortcut: K, S )
verstehe ich nicht. Das ist für mich das gleiche.
Gibt es eigentlich einen shortcut um einen constrain zu editieren? Dreifach-klick ist irgendwie umständlich.
Liste von shortcuts aus dem code:
Constrain coincident                      C
Constrain equal                           E
Create arc by three points                G, 3, A
Create circle by three points             G, 3, C
Create ellipse by 3 points                G, 3, E
Create arc by center                      G, A
Create B-spline                           G, B, B
Create periodic B-spline                  G, B, P
Create circle                             G, C
Create an arc of ellipse                  G, E, A
Create ellipse by center                  G, E, E
Create fillet                             G, F, F
Create corner-preserving fillet           G, F, P
Create an arc of hyperbola                G, H
Create an arc of parabola                 G, J
Create line                               G, L
Create polyline                           G, M
Toggle construction geometry              G, N
Create rounded rectangle                  G, O
Create equilateral triangle               G, P, 3
Create square                             G, P, 4
Create pentagon                           G, P, 5
Create hexagon                            G, P, 6
Create heptagon                           G, P, 7
Create octagon                            G, P, 8
Create regular polygon                    G, P, P
Create regular polygon                    G, P, R
Extend edge                               G, Q
Create rectangle                          G, R
Create slot                               G, S
Trim edge                                 G, T
Create centered rectangle                 G, V
Carbon copy                               G, W
External geometry                         G, X
Create point                              G, Y
Split edge                                G, Z
Constrain horizontally                    H
Constrain vertical distance               I
Constrain angle                           K, A
Constrain block                           K, B
Constrain distance                        K, D
Constrain lock                            K, L
Constrain diameter                        K, O
Constrain radius or weight                K, R
Constrain auto radius/diameter            K, S
Constrain refraction (Snell's law')       K, W
Toggle driving/reference constraint       K, X
Activate/deactivate constraint            K, Z
Constrain horizontal distance             L
Constrain perpendicular                   N
Constrain point onto object               O
Constrain parallel                        P
View sketch                               Q, P
View section                              Q, S
Constrain arc or circle                   R
Constrain symmetrical                     S
Constrain tangent                         T
Constrain vertically                      V
Rectangular array                         Z, A
Copy                                      Z, C
Select associated geometry                Z, E
Select unconstrained DoF                  Z, F
Select horizontal axis                    Z, H
Show/hide internal geometry               Z, I
Connect edges                             Z, J
Select associated constraints             Z, K
Clone                                     Z, L
Move                                      Z, M
Select origin                             Z, O
Select conflicting constraints            Z, P, C
Select malformed constraints              Z, P, M
Select partially redundant constraints    Z, P, P
Select redundant constraints              Z, P, R
Remove axes alignment                     Z, R
Symmetry                                  Z, S
Select vertical axis                      Z, V
Close shape                               Z, W
Switch virtual space                      Z, Z
Convert geometry to B-spline
Copy
Decrease B-spline degree
Decrease knot multiplicity
Delete all constraints
Delete all geometry
Increase B-spline degree
Increase knot multiplicity
Show/hide B-spline control point weight
Show/hide B-spline control polygon
Show/hide B-spline curvature comb
Show/hide B-spline degree
Show/hide B-spline knot multiplicity
M4x
Re: Sketcher shortcuts…
Post by M4x »
Ja, die Testphase läuft gerade.
Bei Interesse ab hier lesen: https://forum.freecadweb.org/viewtopic. ... 10#p539914
Bzgl. R ist das hier der aktuelle Stand meine ich:
abdullah wrote: Sat Oct 16, 2021 7:14 am [...]
The currently selected radius tool will be assigned "R". This does not interfere with those who want to use a specific radius/diameter/smart tool for a specific situation, but it enables a normal user to select once the flavour he wants to use and then trigger that with "R".
Bin noch nicht so zum Testen gekommen. Auf mir liegt gerade ein krankes Kind... :roll:
abdullah
Post by abdullah »
M4x wrote: Sun Oct 24, 2021 11:47 am Ja, die Testphase läuft gerade.
Genau!
Diese smart Radius ist schön, aber manchmal ein bischen zu klug. Gute Besserung für ihres Kind.
rynn wrote: Sun Oct 24, 2021 10:30 am Gibt es eigentlich einen shortcut um einen constrain zu editieren? Dreifach-klick ist irgendwie umständlich.
Bedauerlich gibt es noch nicht. Zurzeit gibt es kein Kommand dafür. Aber, ich denke Sie haben recht. Wir sollten ein solches Kommand haben (und dann, selbstverstandlich, ein Shortcut dafür)... Danke.
C4e
Post by C4e »
Wie steht es um 'D' für diameter?
