scheinbar haben sich die Sketcher shortcuts geändert. git commit 0926a4148bcff11249fd4f56bc30256102ffe105
Den Unterschied zwischen
Sketcher_CompConstrainRadDia / Constrain arc or circle (shortcut: R ) und
Sketcher_ConstrainRadiam / Constrain auto radius/diameter (shortcut: K, S )
verstehe ich nicht. Das ist für mich das gleiche.
Gibt es eigentlich einen shortcut um einen constrain zu editieren? Dreifach-klick ist irgendwie umständlich.
Liste von shortcuts aus dem code:
Constrain coincident C
Constrain equal E
Create arc by three points G, 3, A
Create circle by three points G, 3, C
Create ellipse by 3 points G, 3, E
Create arc by center G, A
Create B-spline G, B, B
Create periodic B-spline G, B, P
Create circle G, C
Create an arc of ellipse G, E, A
Create ellipse by center G, E, E
Create fillet G, F, F
Create corner-preserving fillet G, F, P
Create an arc of hyperbola G, H
Create an arc of parabola G, J
Create line G, L
Create polyline G, M
Toggle construction geometry G, N
Create rounded rectangle G, O
Create equilateral triangle G, P, 3
Create square G, P, 4
Create pentagon G, P, 5
Create hexagon G, P, 6
Create heptagon G, P, 7
Create octagon G, P, 8
Create regular polygon G, P, P
Create regular polygon G, P, R
Extend edge G, Q
Create rectangle G, R
Create slot G, S
Trim edge G, T
Create centered rectangle G, V
Carbon copy G, W
External geometry G, X
Create point G, Y
Split edge G, Z
Constrain horizontally H
Constrain vertical distance I
Constrain angle K, A
Constrain block K, B
Constrain distance K, D
Constrain lock K, L
Constrain diameter K, O
Constrain radius or weight K, R
Constrain auto radius/diameter K, S
Constrain refraction (Snell's law') K, W
Toggle driving/reference constraint K, X
Activate/deactivate constraint K, Z
Constrain horizontal distance L
Constrain perpendicular N
Constrain point onto object O
Constrain parallel P
View sketch Q, P
View section Q, S
Constrain arc or circle R
Constrain symmetrical S
Constrain tangent T
Constrain vertically V
Rectangular array Z, A
Copy Z, C
Select associated geometry Z, E
Select unconstrained DoF Z, F
Select horizontal axis Z, H
Show/hide internal geometry Z, I
Connect edges Z, J
Select associated constraints Z, K
Clone Z, L
Move Z, M
Select origin Z, O
Select conflicting constraints Z, P, C
Select malformed constraints Z, P, M
Select partially redundant constraints Z, P, P
Select redundant constraints Z, P, R
Remove axes alignment Z, R
Symmetry Z, S
Select vertical axis Z, V
Close shape Z, W
Switch virtual space Z, Z
Convert geometry to B-spline
Copy
Decrease B-spline degree
Decrease knot multiplicity
Delete all constraints
Delete all geometry
Increase B-spline degree
Increase knot multiplicity
Show/hide B-spline control point weight
Show/hide B-spline control polygon
Show/hide B-spline curvature comb
Show/hide B-spline degree
Show/hide B-spline knot multiplicity
