Part-design- Aufdicken Fehler
Re: Part-design- Aufdicken Fehler
Antonina wrote: Sun May 22, 2022 4:57 pm Geht bei mir einwandfrei,
Das kann ich mir nur so erklären, dass Du unterschiedliche Dateien öffnest.
Wenn ich in die Datei reinschaue, dann sehe ich z.B. Sketch005:
        <Object name="Sketch005" Extensions="True">
            <Extensions Count="1">
                <Extension type="Part::AttachExtension" name="AttachExtension">
                </Extension>
            </Extensions>
            <Properties Count="13">
                <Property name="AttacherType" type="App::PropertyString">
                    <String value="Attacher::AttachEnginePlane"/>
                </Property>
                <Property name="AttachmentOffset" type="App::PropertyPlacement">
                    <PropertyPlacement Px="0.0000000000000000" Py="0.0000000000000000" Pz="0.0000000000000000" Q0="0.0000000000000000" Q1="0.0000000000000000" Q2="0.0000000000000000" Q3="1.0000000000000000" A="0.0000000000000000" Ox="0.0000000000000000" Oy="0.0000000000000000" Oz="1.0000000000000000"/>
                </Property>
                <Property name="Constraints" type="Sketcher::PropertyConstraintList">
                    <ConstraintList count="0">
                    </ConstraintList>
                </Property>
                <Property name="ExpressionEngine" type="App::PropertyExpressionEngine">
                    <ExpressionEngine count="0">
                    </ExpressionEngine>
                </Property>
                <Property name="ExternalGeometry" type="App::PropertyLinkSubList">
                    <LinkSubList count="0">
                    </LinkSubList>
                </Property>
                <Property name="Geometry" type="Part::PropertyGeometryList">
                    <GeometryList count="0">
                    </GeometryList>
                </Property>
                <Property name="Label" type="App::PropertyString">
                    <String value="Sketch005"/>
                </Property>
                <Property name="MapMode" type="App::PropertyEnumeration">
                    <Integer value="5"/>
                </Property>
                <Property name="MapPathParameter" type="App::PropertyFloat">
                    <Float value="0.0000000000000000"/>
                </Property>
                <Property name="MapReversed" type="App::PropertyBool">
                    <Bool value="false"/>
                </Property>
                <Property name="Placement" type="App::PropertyPlacement">
                    <PropertyPlacement Px="0.0000000000000000" Py="101.0000000000000000" Pz="0.0000000000000224" Q0="0.7071067811865476" Q1="0.0000000000000000" Q2="0.0000000000000000" Q3="0.7071067811865475" A="1.5707963267948968" Ox="1.0000000000000000" Oy="0.0000000000000000" Oz="0.0000000000000000"/>
                </Property>
                <Property name="Shape" type="Part::PropertyPartShape">
                    <Part file="PartShape7.brp"/>
                </Property>
                <Property name="Support" type="App::PropertyLinkSubList">
                    <LinkSubList count="1">
                        <Link obj="DatumPlane001" sub=""/>
                    </LinkSubList>
                </Property>
            </Properties>
        </Object>
Insbesondere ist die Eigenschaft "Geometry" leer, besonders deutlich wird es durch <GeometryList count="0">. Analoges gilt für die Beschränkungen mit <ConstraintList count="0">. Da ist echt nix drin. Es genügt nicht, die Datei zu öffnen, Du musst die Sketche mit Doppelklick im Sketcher bearbeiten.
Antonina
Post by Antonina »
chrisb wrote: Sun May 22, 2022 10:51 pm Das ist sehr verwunderlich. Kannst Du denn in der Konsole den Befehl eintippen? Ansonsten kann das auch Sketcher ValidateSketch.
Ja.
Der Validater, denn muss ich mir zur Gewohnheit machen. Danke.
Lass die Datei links liegen, Loft ist da, die Skizzen darin hier auch leer, ist wohl wieder ein Spässchen von FC, das kommt vor.
Ich will endlich meine Haube fertig, besser gesagt hin-bekommen.
Antonina wrote: Sun May 22, 2022 11:29 pm Ich will endlich meine Haube fertig, besser gesagt hin-bekommen.
Wenn Du dazu noch Hilfe brauchst, dann wäre eine funktionierende Datei für uns hilfreich.
Antonina
Post by Antonina »
Danke!
Darauf werde ich achten.
