Problem with Appimage 0.19 and export Gcode
jl-mando
Post by jl-mando »
Hello all
and thanks to the developpers who makes a wonderful CAD software as Freecad is .
I've however a problem with export .ngc files in Appimage 0.19 version , there is no *.ngc available when I try to export a job .
the same operation is working on 0.18 installed .
my config is :
OS: Ubuntu 16.04.6 LTS (Unity/ubuntu)
Version: 0.19.23463 (Git) AppImage
Hash: adc6db8f32c17e9f67cb82aa7962d1e42ce061c6
Python version: 3.8.6
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
Locale: French/France (fr_FR)
Re: Problem with Appimage 0.19 and export Gcode
You must not use the File->Export command, you should use in Path workbench the post process command after having specified in the job which postprocessor to use.
jl-mando
Post by jl-mando »
Thanks Chrisb
it works fine .
Good to hear. Now enjoy all the new and improved stuff iin 0.19's Path workbench!
ris
Post by ris »
For us, generating a GCODE by using your post process suggestion works only by using only one operation. How to make a GCODE combining multiple operations?
thanks
GeneFC
Post by GeneFC »
ris wrote: Fri Sep 17, 2021 4:59 pm For us, generating a GCODE by using your post process suggestion works only by using only one operation. How to make a GCODE combining multiple operations?
thanks
The standard Path WB g-code generator does all operations by default. You will need to provide more details about what version you are using and what steps you are taking.
This is not a problem with the Path WB but rather a problem with your installation or your technique.
Add the details, and perhaps an FCStd file, and someone should be able to help.
Gene
