HI All,
I'm trying to profile the "cut arms" on the attached model but I can't for the life of me get it to work.
If I change the Z axis in the Job edit>Setup tab then the stock moves to the correct orientation, but the model doesn't follow it so it ends up profiling the end view of the model.
Am I doing this wrong (I presume so) or is it a bug?
Thanks,
Mike.
OS: Windows 10 Version 2009
Version: 0.20.25306 (Git)
Hash: 5f5b3d9b67136edda1f6738f1a83154990f7839d
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/New Zealand (en_NZ)
Bug? Model doesn't follow stock
- Reverse error.FCStd
- (110.82 KiB) Downloaded 47 times
Re: Bug? Model doesn't follow stock
Change the position of "Model-Cut Arm" and let the stock follow.
Bah, why didn't I think of that!
Works now, thank you.
Interestingly when I selected transform to move it, no arrows appeared. I had to do it "manually" in the properties.
Did you select the face you want to be facing up for Z-axis, then select Z-Axis ? ( I find I have to have CAD navigation style selected to get good results with selection) Then click "Refresh" to update stock position, and exit with "OK" to save.tigermm wrote: ↑Thu Sep 23, 2021 11:10 pm HI All,
This worked for me with your file.
OS: Ubuntu 20.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.25645 (Git) AppImage
Hash: 37d9757399b4c2ec30318eb88d7cd7c508246345
Python version: 3.9.7
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.2
You're welcome.
I can confirm the missing transform tool and have no idea why that's the case, because normally clones can be moved like that.
