libarea, used in Path Workbench
This might be a good place to discuss 'libarea' the pocketing/profile generating library that we have adapted from HeeksCNC to use with the Path workbench. So far it is only used for one version of Profiling in Path but I intend on using it with pocketing too. In my experience with HeeksCNC, it does pocketing very well.
I have adapted it to the Path workbench here for testing:
https://github.com/danielfalck/FreeCAD/tree/path_area
We can merge it into the master branch, after some testing.
- sliptonic
Re: libarea, used in Path Workbench
Nice work Dan!
For those that are unfamiliar with libarea, HeeksCNC also uses it to do 3D surfacing operations. This is just a fancy pocket operation where the Z depth of the cutter is controlled by a solid underneath the bounding sketch.
As for the compiling (and PPA) documentation needs to be updated for new dependency. For Ubuntu:
Beyond that it compiles fine on Ubuntu. There is something i would like to see changed if possible. Running cmake infroms the user libarea will be installed in /usr/local/lib folder but what would be nice is to be able to run FreeCAD after compiling it and to have fully functional Path WB without actually making the install. This is how far i tested it for now.
libboost-python-dev
Thanks for checking this out.triplus wrote:As for the compiling (and PPA) documentation needs to be updated for new dependency. For Ubuntu:
Beyond that it compiles fine on Ubuntu. There is something i would like to see changed if possible. Running cmake infroms the user libarea will be installed in /usr/local/lib folder but what would be nice is to be able to run FreeCAD after compiling it and to have fully functional Path WB without actually making the install. This is how far i tested it for now.Code: Select all
libboost-python-dev
I used CMAKE_INSTALL_LIBDIR , similar to what I saw in other workbenches. In the past,on linux systems, it was installed in the /usr/local/lib/python2.7/dist-packages/ so that python could import it.
I see. I don't have much experience with this and looking at:danielfalck wrote:Thanks for checking this out.triplus wrote:As for the compiling (and PPA) documentation needs to be updated for new dependency. For Ubuntu:
libboost-python-dev
https://github.com/danielfalck/FreeCAD/ ... 7d1ecafa7f
Before the path was relative and therefore one could run ./bin/FreeCAD directly after compile and get fully functional Path WB? But currently libarea path is set as absolute path and therefore libarea has to be installed to /usr/local/lib first for ./bin/FreeCAD to pick it up?
If the area lib is together with the other freecad libs, then freecad will pick it up automatically. I think this is the correct way to do it, all libraries compiled together with freecad should stay together and not go to system folders...
Couldn't test yet, but I will do ASAP!
Sounds good.yorik wrote:If the area lib is together with the other freecad libs, then freecad will pick it up automatically. I think this is the correct way to do it, all libraries compiled together with freecad should stay together and not go to system folders...
P.S. I am wondering will Debian complain we "embedded" libarea in FreeCAD?
Thanks for commenting Yorik.yorik wrote:If the area lib is together with the other freecad libs, then freecad will pick it up automatically. I think this is the correct way to do it, all libraries compiled together with freecad should stay together and not go to system folders...
area.pyd (area.so on Linux) is just another FreeCAD module under this scenario. Just like the Path module itself. Path.pyd and PathGui.pyd are located in /Mod/Path. So should area.pyd go into /Mod/Path or /Mod/Path/libarea? Will FreeCAD search recursively one level deeper into /libarea?
Someone please correct me if I'm wrong, but isn't this the reason danielfalck created his branch? This cleans up all the license issues?triplus wrote: P.S. I am wondering will Debian complain we "embedded" libarea in FreeCAD?
"fight the good fight"
No. It should be in one of the folders from the list you get from inside FreeCAD:sgrogan wrote: Will FreeCAD search recursively one level deeper into /libarea?
import sys
print sys.path
sgrogan wrote:Thanks for commenting Yorik.yorik wrote:If the area lib is together with the other freecad libs, then freecad will pick it up automatically. I think this is the correct way to do it, all libraries compiled together with freecad should stay together and not go to system folders...
Yes, I created that branch for two reasons- number 1 to clean up the licensing, number 2 to make it easier to install the Path Workbench.
I don't plan on asking to merge my branch into Master until I have rock solid 'New BSD' headers in all the files and have the CmakeLists.txt file worked out.
