I haven't been able to reproduce. Can you provide some more details and a file?sliptonic wrote:Noted. Will check it out.chrisb wrote: Created path pocket from face
- Looks good
- Editing and opening the Depths tab changes the previously good looking
values to unusables, it multiplies the values by 10 everytime it is opened.
Dogbone dressup
- sliptonic
Re: Dogbone dressup
Re: Dogbone dressup
- open the attached filesliptonic wrote: I haven't been able to reproduce. Can you provide some more details and a file?
- double click on :TC001
- click on Depths
it shows 100 mm start depth (instead of 10), 90 mm end depth (instead of 9) - click ok
the new values are applied Perhaps it's the units? I use mm throughout the model and as standard.
Hope this helps.
- dressup.fcstd
- (15.44 KiB) Downloaded 68 times
Re: Dogbone dressup
Hi Sliptonic, hi Chris,
that's an Error since an half a jear or more.... You will find some post reporting that in the forum.
Gruß Herbert
Re: Dogbone dressup
Chris,
I downloaded your file, and I do not see the problem of 10x scaling. I repeatedly opened the TC001, and it never changed. I am working in US customary units, but the translation is exactly 10 mm Start Depth and 9 mm Final Depth. I suspect the long-standing problem of "." vs "," for the decimal separator could be the problem.
In my case the Step Down is always metric, ignoring my choice of units. (I am thoroughly bi-lingual in units, since I spent my entire career working only in metric. My machine tools have US units, however.)
[attachment=0]Picture1.jpg[/attachment
OS: Windows 7
Version: 0.17.8761 (Git)
Hash: 96e9b7ee5b5728d859c1f0dc3e76d7fd4d137c7d
Python version: 2.7.8
OCC version: 7.0.0
Gene
OS: Windows 7
OCC version: 7.0.0
Gene
- Picture1.jpg (39.42 KiB) Viewed 2490 times
Re: Dogbone dressup
I have a fix for that which should be coming soon. It was recently introduced - in essence none of the post processor scripts currently sets the unit in the g-code (G20 vs. G21).GeneFC wrote: In my case the Step Down is always metric, ignoring my choice of units. (I am thoroughly bi-lingual in units, since I spent my entire career working only in metric. My machine tools have US units, however.)
Gene
Re: Dogbone dressup
I have my own post processor, which works correctly to convert all units and to assign G20 to my G-code files. The FreeCAD internal storage of G-code is only metric, so the conversion is easy.
This quirk is not really a function of the post processor in any case. This is within the FreeCAD display, before any post processing. There are many, many places throughout FreeCAD where a similar thing happens. Not really a big problem for me.
Gene
Gene
Re: Dogbone dressup
I tried to change my system settings but I don't know how. (I am pretty sure that used to use the dot as decimal separator)GeneFC wrote:I suspect the long-standing problem of "." vs "," for the decimal separator could be the problem.
The system uses this environment:
GDM_LANG=en_US
LANG=en_US.UTF-8
LANGUAGE=en_US
The FreeCAD settings use English as language
Nevertheless, my decimal separator is still the comma ",".
However it is not really a big deal for me either. Is this handled in C++ or in python? If it is the latter I would try to trace it down. Any hints?
Re: Dogbone dressup
hi, one question:
is it noticed that dogbone do not work on "ccw"-cutting direction?
i did some quick research about it, but can't find anything about it till now. (I'm new on it to learn about Mantis/bugtracker. Still trying to figure out...maybe it's my browser, or my fault, can't really sort the entries at moment )
UPDATE: It was my fault with Mantis..
OS: Ubuntu 16.04.3 LTS
Version: 0.17.13217 (Git)
Build type: None
Hash: 89275766de909a5c1f36e962806dc7b4a0b0f47b
Python version: 2.7.12
OCC version: 7.1.0
Re: Dogbone dressup
Ups, it was fault again..., sorry!
didn't notice that there is an Option "Side" in dogbone-dressup that have to be set correctly....
