Default is the Start WB
sliptonic wrote:open the file
Extension is not a python addable version: 'App::OriginGroupExtension'
Can't find Origin for "Body"
Extension is not a python addable version: 'Gui::ViewProviderOriginGroupExtension'
sliptonic wrote:switch to the path workbench
Select the wall of one of the circular holes
click the helix cut icon.
Path workbench activated
DeprecationWarning: For future usage 'Curve' will return 'Line' which is infinite instead of the limited 'LineSegment'.
If you need a line segment then use this:
Part.LineSegment(edge.Curve,edge.FirstParameter,edge.LastParameter)
To suppress the warning set BaseApp/Preferences/Mod/Part/General/LineOld to false
- path.PNG (90.35 KiB) Viewed 2366 times
sliptonic wrote:It should open the dialog, add the hole coordinates, and generate a green path.
Click OK, no new warnings.
