How to activate openCamLib after compiling it
Re: How to activate openCamLib after compiling it
Postby chrisb » Sat Dec 09, 2017 9:14 am
herbk wrote:
Sat Dec 09, 2017 7:53 am
Hi Chris,
I'l try if there are not to much dependencies.... You know i use OpenSuse... there is no package "texlive-latex-base", so i have to compile it by myself to (with resolving the dependencies... and so on..).
Hi Herbert, I see the problems and I can understand that you don't really enjoy going through this searching for dependencies and eliminating them.
I searched the suse software for the packages and found the following:
- texlive-latex, I guess that's all it needs. I think it is used for the creation of the documentation only.
- doxygen exists for Suse as well
- boost contains the boost libraries, be sure to get the development version
- git exists of course as well
I would give it a try with these.
Chris
Postby chrisb » Sat Dec 09, 2017 11:47 am
you can minimize the dependencies if you don't prepare to create the docs. They are not created with the default make anyway, only if you explicitely 'make doc'.
The minimized procedure is:
- install cmake, git and boost developer version. This is on Ubuntu/Debian like systems: 'apt-get install cmake git libboost-all-dev'
- git clone https://github.com/aewallin/opencamlib
- cd opencamlib/src
- edit the file CMakeLists.txt and change the option value of BUILD_DOC from ON to OFF
- cmake .
- make
- sudo make install
herbk
Postby herbk » Sat Dec 09, 2017 1:53 pm
Hi Chris,
thx, i will try, but not before today evening.
boost-dev i have ollready installed, doxygen is just a "documentation creater" maybe i can switch it off to
In that moment (better: since 3 hours) runs a 3D poket operation on my machine. Only a little part, but i want to have a nice surface of a round object and so i work with 0,1mm stepdown only.
The operation shows some foults, but for that i will open a new thread an show some pics.
Gruß Herbert
herbk
Postby herbk » Sun Jan 14, 2018 1:03 pm
Hi Chris,
again about my OCL problem...
Where is FC surching for OCL? Its installed on my system to that folders:
/usr/lib/opencamlib
/usr/lib/opencamlib/libocl.so.11.10.84
/usr/lib/python2.7/site-packages/STLTools.py
/usr/lib/python2.7/site-packages/STLTools.pyc
/usr/lib/python2.7/site-packages/STLTools.pyo
/usr/lib/python2.7/site-packages/camvtk.py
/usr/lib/python2.7/site-packages/camvtk.pyc
/usr/lib/python2.7/site-packages/camvtk.pyo
/usr/lib/python2.7/site-packages/procmemory.py
/usr/lib/python2.7/site-packages/procmemory.pyc
/usr/lib/python2.7/site-packages/procmemory.pyo
/usr/lib/python2.7/site-packages/pyocl.py
/usr/lib/python2.7/site-packages/pyocl.pyc
/usr/lib/python2.7/site-packages/pyocl.pyo
/usr/lib64/python2.7/site-packages/ocl.so
But FC did not find it. All things you are postet before are done, but no effect.
/usr/local/lib/ exists, but it's a emphty folder...
Where is FC searching for OCL?
Gruß Herbert
Postby chrisb » Sun Jan 14, 2018 1:13 pm
I will check later.
Postby chrisb » Sun Jan 14, 2018 6:22 pm
Is there a symbolic link libocl.so in the directory /usr/lib/opencamlib/ pointing to the library file? If not create it (see below).
On my system the library is not in the ldconfig path, which is strange, because it works out of the box. Perhaps FreeCAD is looking directly in the directory.
Please try the following:
- create a directory /usr/local/lib/opencamlib
- copy the file libocl.so.11.10.84 into that directory
- create a link inside that directory: ln -s libocl.so.11.10.84 libocl.so
bmsleight
Postby bmsleight » Sat Apr 14, 2018 9:41 am
Any tips on what I am doing wrong ?
"operation requires OpenCamLib"
Installed openCamLib via git & Make (as per instruction in this thread no errors). Using the latest "AppImage"
bms@FortBoyard:~/FreeCAD-App$ ls /usr/local/lib/opencamlib/ -l
total 492
lrwxrwxrwx 1 root root     18 Apr 14 10:26 libocl.so -> libocl.so.11.10.92
-rw-r--r-- 1 root root 502040 Apr 14 10:25 libocl.so.11.10.92
bms@FortBoyard:~/FreeCAD-App$ ./FreeCAD_0.17.13509.glibc2.17-x86_64.AppImage
FreeCAD 0.17, Libs: 0.17R13509 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
Path workbench activated
PathOpGui.INFO: Title: 'Surface'
Surfacing Select Mode
Free Select
This operation requires OpenCamLib to be installed.
Postby chrisb » Sat Apr 14, 2018 1:23 pm
That's an Appimage problem. please search the forum for appimage related topics, I remember the problem was discussed there.
You didn't tell us much about your system. Can you install a "native" FreeCAD?
quick61
Postby quick61 » Tue Mar 26, 2019 6:42 pm
I"m sure you all would love to go over this one more time, but...
When I try to enter import OCL in the Python console I get -
>>> import OCL
ImportError: No module named OCL
I have been through all 3 pages of this thread and have done / tried everything mentioned. Compiled and installed opencamlib
Install the project...
/usr/bin/cmake -P cmake_install.cmake
-- Install configuration: "Release"
-- Installing: /usr/local/lib/opencamlib/libocl.so.2018.08.122
-- Up-to-date: /usr/local/lib/opencamlib/libocl.so
-- Up-to-date: /usr/local/include/opencamlib/arc.hpp
-- Up-to-date: /usr/local/include/opencamlib/bbox.hpp
-- Up-to-date: /usr/local/include/opencamlib/ccpoint.hpp
-- Up-to-date: /usr/local/include/opencamlib/clpoint.hpp
-- Up-to-date: /usr/local/include/opencamlib/line.hpp
-- Up-to-date: /usr/local/include/opencamlib/path.hpp
-- Up-to-date: /usr/local/include/opencamlib/stlreader.hpp
-- Up-to-date: /usr/local/include/opencamlib/stlsurf.hpp
-- Up-to-date: /usr/local/include/opencamlib/triangle.hpp
-- Up-to-date: /usr/local/include/opencamlib/point.hpp
-- Up-to-date: /usr/local/include/opencamlib/ballcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/bullcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/compositecutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/conecutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/cylcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/ellipseposition.hpp
-- Up-to-date: /usr/local/include/opencamlib/millingcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/ellipse.hpp
-- Up-to-date: /usr/local/include/opencamlib/adaptivepathdropcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/pathdropcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/batchdropcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/pointdropcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/brent_zero.hpp
-- Up-to-date: /usr/local/include/opencamlib/kdnode.hpp
-- Up-to-date: /usr/local/include/opencamlib/kdtree.hpp
-- Up-to-date: /usr/local/include/opencamlib/numeric.hpp
-- Up-to-date: /usr/local/include/opencamlib/lineclfilter.hpp
-- Up-to-date: /usr/local/include/opencamlib/clfilter.hpp
-- Up-to-date: /usr/local/include/opencamlib/halfedgediagram.hpp
-- Up-to-date: /usr/local/include/opencamlib/operation.hpp
-- Up-to-date: /usr/local/include/opencamlib/batchpushcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/fiberpushcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/fiber.hpp
-- Up-to-date: /usr/local/include/opencamlib/interval.hpp
-- Up-to-date: /usr/local/include/opencamlib/waterline.hpp
-- Up-to-date: /usr/local/include/opencamlib/adaptivewaterline.hpp
-- Up-to-date: /usr/local/include/opencamlib/weave.hpp
-- Up-to-date: /usr/local/include/opencamlib/simple_weave.hpp
-- Up-to-date: /usr/local/include/opencamlib/smart_weave.hpp
-- Up-to-date: /usr/local/include/opencamlib/weave_typedef.hpp
-- Up-to-date: /usr/local/include/opencamlib/tsp.hpp
Enabled Path_experimental as per - https://www.freecadweb.org/wiki/Path_experimental/en
Made sure there was a symbolic link in /usr/lib/opencamlib/
:/usr/lib/opencamlib$ ls
libocl.so  libocl.so.2018.08
The strange thing is, when I run 3D Surface, it kind of works, i get no error messages like opencamlib needs to be installed for this operation, or any such, in face when I do run 3D surface on a part, the console output is -
StepOver is  50
base object: Clone
calculation took  4.24623012543  s
points received: 155367
points after optimization: 124
Though I don't get the expected results and FreeCAD will not allow me to select any faces from the model, telling me that selection is not allowed on whatever face/edge I hover the mouse over.
So, can someone tell me what I'm missing, or what is going on? My FC info -
OS: Ubuntu 18.04.2 LTS
Version: 0.18.16093 (Git)
Branch: releases/FreeCAD-0-18
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
Python version: 2.7.15rc1
Qt version: 5.9.5
