oh
I am getting a boost error. is this what you got?
Where, in the build or config? I haven't been able to even get OCL to config for Python 3, flat out refuses, with py3 flag on it only configs using 2.7.
erich@erich-Gazelle:~/opencamlib/build$ cmake -DBUILD_PY_LIB=ON -DUSE_PY_3=ON ../src
-- Note: will NOT build emscripten library
-- C++ compiler version: 7.4.0 [/usr/bin/c++]
-- setting gcc options: -Wall -Wno-deprecated -pedantic-errors
CMake Warning (dev) at /usr/share/cmake-3.10/Modules/FindOpenMP.cmake:310 (if):
if given arguments:
"TRUE"
An argument named "TRUE" appears in a conditional statement. Policy
CMP0012 is not set: if() recognizes numbers and boolean constants. Run
"cmake --help-policy CMP0012" for policy details. Use the cmake_policy
command to set the policy and suppress this warning.
/usr/share/cmake-3.10/Modules/FindOpenMP.cmake:425 (_OPENMP_GET_SPEC_DATE)
CMakeLists.txt:101 (find_package)
This warning is for project developers. Use -Wno-dev to suppress it.
if given arguments:
"TRUE"
-- found OpenMP, compiling with flags: -fopenmp
-- version_string.cmake git set GIT_COMMIT_ID: 2018.08-131-g054d5fd
-- OpenCamLib version: 2018.08.122
-- configuring src/cutters
-- configuring src/geo
-- configuring src/algo
-- configuring src/dropcutter
-- configuring src/common
-- Boost version: 1.65.1
-- CMake version < 3.12.0
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1094 ] _boost_TEST_VERSIONS = 1.65.1;1.65.0;1.65;1.64.0;1.64;1.63.0;1.63;1.62.0;1.62;1.61.0;1.61;1.60.0;1.60;1.59.0;1.59;1.58.0;1.58;1.57.0;1.57;1.56.0;1.56;1.55.0;1.55;1.54.0;1.54;1.53.0;1.53;1.52.0;1.52;1.51.0;1.51;1.50.0;1.50;1.49.0;1.49;1.48.0;1.48;1.47.0;1.47;1.46.1;1.46.0;1.46;1.45.0;1.45;1.44.0;1.44;1.43.0;1.43;1.42.0;1.42;1.41.0;1.41;1.40.0;1.40;1.39.0;1.39;1.38.0;1.38;1.37.0;1.37;1.36.1;1.36.0;1.36;1.35.1;1.35.0;1.35;1.34.1;1.34.0;1.34;1.33.1;1.33.0;1.33
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1096 ] Boost_USE_MULTITHREADED = TRUE
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1098 ] Boost_USE_STATIC_LIBS =
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1100 ] Boost_USE_STATIC_RUNTIME =
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1102 ] Boost_ADDITIONAL_VERSIONS =
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1104 ] Boost_NO_SYSTEM_PATHS =
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1172 ] Declared as CMake or Environmental Variables:
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1174 ] BOOST_ROOT =
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1176 ] BOOST_INCLUDEDIR =
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1178 ] BOOST_LIBRARYDIR =
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1180 ] _boost_TEST_VERSIONS = 1.65.1;1.65.0;1.65;1.64.0;1.64;1.63.0;1.63;1.62.0;1.62;1.61.0;1.61;1.60.0;1.60;1.59.0;1.59;1.58.0;1.58;1.57.0;1.57;1.56.0;1.56;1.55.0;1.55;1.54.0;1.54;1.53.0;1.53;1.52.0;1.52;1.51.0;1.51;1.50.0;1.50;1.49.0;1.49;1.48.0;1.48;1.47.0;1.47;1.46.1;1.46.0;1.46;1.45.0;1.45;1.44.0;1.44;1.43.0;1.43;1.42.0;1.42;1.41.0;1.41;1.40.0;1.40;1.39.0;1.39;1.38.0;1.38;1.37.0;1.37;1.36.1;1.36.0;1.36;1.35.1;1.35.0;1.35;1.34.1;1.34.0;1.34;1.33.1;1.33.0;1.33
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1279 ] location of version.hpp: /usr/include/boost/version.hpp
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1303 ] version.hpp reveals boost 1.65.1
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1389 ] guessed _boost_COMPILER = -gcc7
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1399 ] _boost_MULTITHREADED = -mt
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1443 ] _boost_RELEASE_ABI_TAG = -
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1445 ] _boost_DEBUG_ABI_TAG = -d
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1507 ] _boost_LIBRARY_SEARCH_DIRS_RELEASE = /usr/include/lib;/usr/include/../lib;/usr/include/stage/lib;PATHS;C:/boost/lib;C:/boost;/sw/local/lib_boost_LIBRARY_SEARCH_DIRS_DEBUG = /usr/include/lib;/usr/include/../lib;/usr/include/stage/lib;PATHS;C:/boost/lib;C:/boost;/sw/local/lib
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1657 ] Searching for PYTHON_LIBRARY_RELEASE: boost_python-gcc7-mt-1_65_1;boost_python-gcc7-mt;boost_python-mt-1_65_1;boost_python-mt;boost_python
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1708 ] Searching for PYTHON_LIBRARY_DEBUG: boost_python-gcc7-mt-d-1_65_1;boost_python-gcc7-mt-d;boost_python-mt-d-1_65_1;boost_python-mt-d;boost_python-mt;boost_python
-- [ /usr/share/cmake-3.10/Modules/FindBoost.cmake:1783 ] Boost_FOUND = 1
-- Could NOT find Boost
Boost include path: /usr/include
Could not find the following Boost libraries:
boost_python
No Boost libraries were found. You may need to set BOOST_LIBRARYDIR to the directory containing Boost libraries or BOOST_ROOT to the location of Boost.
-- Boost_INCLUDE_DIR = /usr/include
-- Boost_INCLUDE_DIRS = /usr/include
-- Boost_LIBRARY_DIRS =
-- Boost_LIBRARIES =
-- PYTHON_SITE_PACKAGES = /usr/local/lib/python2.7/dist-packages
-- PYTHON_ARCH_PACKAGES = /usr/local/lib/python2.7/dist-packages
-- PYTHON_INCLUDE_DIRS = /usr/include/python2.7
-- PYTHON_LIBRARIES = /usr/lib/x86_64-linux-gnu/libpython2.7.so
-- linking python binary ocl.so with boost:
-- Found doxygen. Documentation can be built with 'make doc'
-- type:
-- 'make' for a normal build
-- 'make -j8' to build faster (if you have many cpus)
-- 'make install' to install
-- 'make package' to build a binary deb-packate
-- 'make spackage' to build debian source-packages
-- 'make test' to run the tests
-- Configuring done
-- Generating done
-- Build files have been written to: /home/erich/opencamlib/build
sudo apt install libboost-program-options-dev
>>> sys.path.append('/usr/local/lib/python2.7/dist-packages')
>>> import ocl
ImportError: /usr/local/lib/python2.7/dist-packages/ocl.so: undefined symbol: _ZNK5boost6python7objects21py_function_impl_base9max_arityEv
sudo apt install libboost-all-dev
cmake -DBUILD_PY_LIB=ON -DUSE_PY_3=ON ../src -Wno-dev
import sys
import ocl
ImportError: dynamic module does not define module export function (PyInit_ocl)
wwwwwoooooohoooooo!!!!!
wwwwwoooooohoooooo!!!!! is right! That did it. Thank you ever so much! I'v now got it working too. Only difference is I grabbed the 3.15.0-rc2 version. Worked like a champ. OCL is now working on this Kubuntu 18.04.2 LTS install. We're going to want to make a note of this somewhere I'd think.Erich Schulz wrote: ↑Wed Jun 26, 2019 6:59 am wwwwwoooooohoooooo!!!!!
so I cracked it!! I downloaded the latest version of cmake from here: https://cmake.org/download/
(i just grabbed the .sh file, executed it and then rather than `cmake blah` I ran `~/cmake/cmake blah)
fyi I was on cmake 3.10 and am now on 3.14.5.
I have updated the wikipage and filed an issue https://github.com/aewallin/opencamlib/issues/70
your very welcome! and thanks to the others who helped point in the general directionquick61 wrote: ↑Wed Jun 26, 2019 2:00 pm wwwwwoooooohoooooo!!!!! is right! That did it. Thank you ever so much! I'v now got it working too. Only difference is I grabbed the 3.15.0-rc2 version. Worked like a champ. OCL is now working on this Kubuntu 18.04.2 LTS install. We're going to want to make a note of this somewhere I'd think.
Mark
THANK YOU!!! This issue was driving me (and pretty sure, half the people on this forum) crazy. Updating cmake did the trick!Erich Schulz wrote: ↑Wed Jun 26, 2019 6:59 amwwwwwoooooohoooooo!!!!!
