Path.Area: Welcome, to the new era!
herbk
Re: Path.Area: Welcome, to the new era!
Postby herbk » Sun Mar 12, 2017 8:26 pm
also it is important to look at the tool's shape, - not each contour ist to make with each rotary chisel.
Gruß Herbert
sliptonic
Postby sliptonic » Mon Mar 13, 2017 7:10 pm
@realthunder,
I think I remember you posting something about documentation for PathArea and FeatureArea but I'm having trouble finding it.
What's the best place to find docs?
realthunder
Postby realthunder » Tue Mar 14, 2017 4:44 pm
sliptonic wrote:@realthunder,
The Path.Area python object is documented through python docstring. You can find the document on each method using FC python console auto-complete by hovering mouse on the method, or simply
print Path.Area.<method>.__doc__
To get the parameter document, you can either hovering mouse on any of the FeatureArea's property, or
print Path.Area.setParams.__doc__
sliptonic
Postby sliptonic » Tue Mar 14, 2017 5:15 pm
I'm playing with PathArea to see if I can do things like 'contour' in a faster, cleaner, and more reliable way. These kinds of 2.5D operations are common and I'm not sure exactly how to handle them.
Starting with my profile object (note the overhang)
I want to get a contour path like this:
But since PathArea calculates the sections itself, I get a path like this:
If I use TechDraw.findShapeOutline() to get the silhouette and give that to PathArea I get a correct contour path like this:
But as a 2D object, I only get the single depth.
I also tried the makeSections() function and passed in depths but I think this is intended to cue PathArea the heights to create the sections of the solid and not duplicating a section at various heights.
Thoughts?
realthunder
Postby realthunder » Tue Mar 14, 2017 5:23 pm
sliptonic wrote:I'm playing with PathArea to see if I can do things like 'contour' in a faster, cleaner, and more reliable way. These kinds of 2.5D operations are common and I'm not sure exactly how to handle them.
Thoughts?
Ah, I got the notification, finally.
You'll need to find a way to fill the overhang. You can simply select the bottom overhang face, and extrude a solid, and create a FeatureArea containing both your model and the filling solid, then do an offset will get what you want.
realthunder
Postby realthunder » Tue Mar 14, 2017 5:37 pm
About the lathe pattern, I'll add more build-in pocket patterns when I got time. With a few more exotic patterns, maybe PathArea can be used to build a 3D printing slicer :D. Every open source slicer is using ClipperLib anyway.
Meanwhile, you can use sketch to manually create straight line patterns. With the new sketcher array function, it's a piece of cake.
Once the sketch is done. Turn off FeatureArea packet. You'll get a cut face. Select the sketch in the TreeView, and Ctrl select the face in the 3D viewer window (not the Tree view), and create a new FeatureArea. Change Operation to 'Intersection, Explode to 'True'. You'll get the clipped wire. Select this FeatureArea, and create a FeaturePath of it. Set SortMode to 'None', there you go, a very "lathe alike" pattern. The rapid move still need some close look though. See the attached model file.
Screenshot from 2017-03-15 01-35-55.png (261.05 KiB) Viewed 1030 times
lathepart1.fcstd
(29.17 KiB) Downloaded 21 times
sliptonic
Postby sliptonic » Wed Mar 15, 2017 12:49 am
I'm trying to manually set section heights.
I have a list of desired heights like
L = [25.0, 20.0, 15.0, 10.0, 5.0, 0.0]
profile = Path.Area(Offset=5.0,SectionCount=len(L))
profile.setPlane(Part.makeCircle(10))
profile.add(myObj)
profile.makeSections(heights=L)
But the sections don't seem to be at those heights. Instead they're at [5,4,3,2,1,0]
The number of sections always matches the length of the list but the actual postion always seems to increment by 1.
I've tried SectionMode set to workplane and absolute.
realthunder
Postby realthunder » Wed Mar 15, 2017 2:08 am
sliptonic wrote:I'm trying to manually set section heights.
Could you please attach your model file.
sliptonic
Postby sliptonic » Wed Mar 15, 2017 4:53 am
Well, the problem is showing up in a script so the model file isn't useful, but this macro reproduces it:
import Path
myObj = App.ActiveDocument.addObject('Part::Feature','workpiece')
myObj.Shape = Part.makeBox(10,10,10)
myObj.ViewObject.Transparency = 70
profile.add(myObj.Shape)
pp = Path.fromShapes(profile.getShape())
Path.show(pp)
for i in pp.Commands:
    print i
realthunder
Postby realthunder » Wed Mar 15, 2017 7:12 am
sliptonic wrote:
realthunder wrote:
sliptonic wrote: Well, the problem is showing up in a script so the model file isn't useful, but this macro reproduces it:
makeSections returns a list of Area objects containing section slices. The returned area object has the same parameter setting as its parent, but independent of the parent, and independent of each other. You can do whatever you want for each individual sections. It doesn't affect the original Area object. The returned sections are transformed according to the work plane selection, which is a bit inconvenient. I've changed that behavior, and return the section in its correct position. Please sync with my branch. The modified code is shown below.
App.newDocument()
import Path
sections = Path.Area(Offset=5.0,SectionMode=0).add(myObj.Shape).makeSections(heights=L)
for s in sections:
	Part.show(s.getShape())
