PathGui: ViewProviderPath visual enhancement #625
realthunder
Postby realthunder » Sat Mar 18, 2017 7:05 am
Hello fellow Pathers, I've just submit a patch for ViewProviderPath with the following enhancement,
  • Enabled preselect
  • Shows GCode command and movement direction when preselected
  • Support single/multi-stepping using property 'StartIndex' and 'ShowCount'
Screenshot from 2017-03-18 14-51-42.png (176.89 KiB) Viewed 1083 times
You are welcome to try my branch at https://github.com/realthunder/FreeCAD/ ... iewEnhance
One problem, though. I've slightly changed Path::Command to make the output command shorter if asked. But it caused Path test failure. Is it necessary for a gcode file to have a fixed number of decimals? Could Path test author have a look at it? The error looks like these.
  File "C:\projects\freecad\build\Mod\Path\PathTests\TestPathCore.py", line 99, in test10
    self.assertEqual(p.toGCode(), 'G1 X1.000000 Y0.000000\nG1 X0.000000 Y2.000000\nG1 X1.000000 Y0.000000\n')
AssertionError: 'G1 X1.00000 Y0.00000\nG1 X0.00000 Y2.00000\nG1 X1.00000 Y0.00000\n' != 'G1 X1.000000 Y0.000000\nG1 X0.000000 Y2.000000\nG1 X1.000000 Y0.000000\n'
It is kind of weird, because the original Path::Command C++ code uses 5 decimal precision, which is what I used for default. How come it didn't cause problem before?
Re: PathGui: ViewProviderPath visual enhancement #625
Postby chrisb » Sat Mar 18, 2017 10:00 am
GCode itself doesn't require a certain precision. The precision depended in the old days on the machines capabilities. Thus until now it was only a matter for the post processor. Since the new display gives a hint to the GCode generated it might well use the post processors information. However, I don't like the mixing of levels, until now the post processor was completely independent from the rest of the path workbench.
What I would like to see:
- All calculations should use the full double precision.
- Make all post processors precision aware by means of a parameter.
- The precision can be defined in the Job.
- If set, it is transferred to the post processor
- if set, it is used for display if needed.
sliptonic
Postby sliptonic » Sat Mar 18, 2017 1:56 pm
Realthunder,
This is a really nice feature! I especially like being able to limit the elements shown and set the start index. It will be very helpful to inspect the path when it gets dense.
This does break the regular Path operations. I'm getting this error trying to create a new contour or other operation. Should be an easy fix but might be needed in a few places. :
  File "<string>", line 6, in <module>
  File "/home/brad/FC/Mod/Path/PathScripts/PathLoadTool.py", line 104, in __init__
    vobj.setEditorMode('ShowFirstRapid', mode)
AttributeError: Property container has no property 'ShowFirstRapid'
Don't worry about the test failure. The tests are too simplistic. They just compare output to hard-coded values so they're not taking precision into account at all. The tests should be re-written.
Path uses the preferences 'number of decimals' setting most places and the fmt() function from PathUtils in others. fmt() is hard-coded to 4 decimal places. I agree with chrisb that we need a preference for post-processor precision which would default into the job. I will work on that. issue #2970
One thing to clarify, the display on the screen is NOT derived from the output gcode. It's built from the path commands so it should never be affected by any output precision setting.
realthunder
Postby realthunder » Sat Mar 18, 2017 3:44 pm
sliptonic wrote:This does break the regular Path operations. I'm getting this error trying to create a new contour or other operation. Should be an easy fix but might be needed in a few places. :
Oh, right, I removed that property from ViewProviderPath, since it can now set a start index, this property is obsolete, which effectively means StartIndex=1
mlampert
Postby mlampert » Sun Mar 19, 2017 2:40 am
realthunder wrote:
It seems you increased the precision from 5 to 6 digits, that's fine. I don't know how you print the command but be aware that it has to be valid g-code, you can't use "%g" because it'll use exponents. 5 digits was a compromise between resolution (100nm) and .fcstd file size.
realthunder
Postby realthunder » Sun Mar 19, 2017 2:45 am
mlampert wrote:It seems you increased the precision from 5 to 6 digits, that's fine. I don't know how you print the command but be aware that it has to be valid g-code, you can't use "%g" because it'll use exponents. 5 digits was a compromise between resolution (100nm) and .fcstd file size.
No, I kept the default 5 digits. That's why I think it is strange. How can the test pass before? And no, I am not using %g, but C++ stringstream.
mlampert
Postby mlampert » Sun Mar 19, 2017 3:05 am
realthunder wrote: No, I kept the default 5 digits. That's why I think it is strange. How can the test pass before? And no, I am not using %g, but C++ stringstream.
I'm not sure if you haven't reverted the fix for #2770. Could you verify that this doesn't create entries like "1e4" if the value is 10000. Preferrably in a unit test?
mlampert
Postby mlampert » Sun Mar 19, 2017 3:10 am
Arrrgh - I got confused. The current default precision is 6 digits, 10nm, and you decreased it to 5. The set precision in the old code is not used, the formatting comes from std::to_string which always results in 6 digits.
My bad, it's been a while since I looked at that code.
In order to fix the unit tests you just have to increase your default precision to 6.
realthunder
Postby realthunder » Sun Mar 19, 2017 3:31 am
Mystery solved! Change committed.
mlampert
Postby mlampert » Sun Mar 19, 2017 4:19 am
realthunder wrote:Mystery solved! Change committed.
yay - can you still verify that the stream operator for doubles doesn't use exponents please
