PathGui: ViewProviderPath visual enhancement #625
realthunder
Re: PathGui: ViewProviderPath visual enhancement #625
Postby realthunder » Sun Mar 19, 2017 4:32 am
mlampert wrote:yay - can you still verify that the stream operator for doubles doesn't use exponents please
According to cppreference http://en.cppreference.com/w/cpp/io/ios_base/setf, you need to specifically setf with std::scientific to get the exponents. I used std::fixed (fixed decimal) with a given precision (now defaults to 6), which should be equivalent to std::to_string
sliptonic
Postby sliptonic » Fri Mar 24, 2017 5:37 pm
I really like the improvements to the viewprovider but I'm curious why you switched the path color from green to blue?
This isn't a big deal but all the Path icons use green to show generated paths. The change may cause confusion.
Power users, please weigh in.
realthunder
Postby realthunder » Fri Mar 24, 2017 5:42 pm
sliptonic wrote:I really like the improvements to the viewprovider but I'm curious why you switched the path color from green to blue?
Really? That must be a mistake. I was trying different color to distinguish it from the selection color. I remembered I settle down with a lighter green than the normal selection color. Then later I changed to Path selection style to bounding box, so no need to play with the Path color any more. I forgot about the color change. Please make a pull request to change it back.
realthunder
Postby realthunder » Fri Mar 24, 2017 5:45 pm
The funny thing is that, when I saw your latest screen capture with the blue path, I thought maybe you changed it to distinguish it with selection :lol:
realthunder
Postby realthunder » Fri Mar 24, 2017 5:48 pm
Ah, I saw the mistake in the code. I'll make a pull request and change it back.
realthunder
Postby realthunder » Fri Mar 24, 2017 8:34 pm
sliptonic wrote:I'm curious why you switched the path color from green to blue?
Color restored, and it's been merged to the master.
Postby chrisb » Fri Mar 24, 2017 10:20 pm
I had thought it was to distinguish different versions at a glance :) .
