mlampert wrote:Given that the default for all of FC is the old behaviour I think that would be great - and adding a setting to the preferences would be awesome (although I'm wondering if it should be in Path preferences. Given that this is a global feature maybe it should go into "Display" and Path should use whatever is the global preference)
First of all, before I patched ViewProviderPath, it has no selection support. I think maybe the selection support got disrupted when FC upgraded its inventor selection mechanism. The default selection style for all other objects in FC are still kept the same as before. I only defaults the bounding box style to Path, because if not, then a selection of any individual Path (or the whole Path), will make it green, which obscure the rapid move. That is why I think this setting should go into Path. The setting I will be adding is,
* Shape, like all other objects in FC. Be aware that for Path, this will obscure rapid move.
* Bounding box, like what it is now
* None, disable selection altogether
What do you think?
I'll check the arrow problem soon.
