Conversion to Path.Area
sliptonic
Postby sliptonic » Sat May 13, 2017 4:38 pm
I've submitted Pull Request 755 for review. This reworks the Contour and PathMillFace operations to use Path.Area instead of the older libarea wrapper and heekscnc python code.
From my use, contour is much more stable and I haven't found a shape that gives it problems yet. MillFace has several new fill patterns available as well
Path.Area is definitely the future of Path and it will take some time to finish converting the other operations but I wanted to get our power users reviewing this as soon as possible.
Please let me know if you see any silly mistakes or obvious bugs.
It might not pass the unit tests yet but should build o.k and run. I'll be checking that next
roivai
Re: Conversion to Path.Area
Postby roivai » Sat May 13, 2017 8:22 pm
I tried your branch. I tried to contour this simple shape and I think the path got offset by the tool diameter and not the radius?
The tool I have selected is 6mm and the two holes are also 6mm in diameter. The contour path seems to be 6mm offset. For comparison, the bore in the middle hole is done with PathHelix and there it clearly shows that it cuts closer to the solid. ToolController is the same for both ops. Did I do something wrong?
herbk
Postby herbk » Sun May 14, 2017 8:02 am
Good morning sliptonic, realthunder,
thx for the work and the info. Seams i have to pull out my old laptop (with the mint on it) to try the new things. :D :D
Somewhere a missing /2 after reading the tool diameter?
Or getting already the radius and take it *2 (like in PathSurface.py) ?
Edit: Did you try it with one of my "problematc shapes" (based on b-splines) to? - or is that a problem which is caused by another component of FC?
Edit edit: a other thing i see on Roivai's pic: one of the rapid pathes seams to be critical. there is a diagonal xz (or yz) movement which will damage the workpeace.
Traeger_mittelteil.fcstd
(253.09 KiB) Downloaded 15 times
Gruß Herbert
sliptonic
Postby sliptonic » Sun May 14, 2017 1:48 pm
The offset problem still has stumped this morning. It's not the simple case of a doubled radius. I'll find it yet.
Yes, I tested it with your b spline shapes and it worked with all. I'm sure you'll do your best to "raise the bar" though ;)
I'll take a look at the rapid move.
sliptonic
Postby sliptonic » Tue May 16, 2017 12:28 pm
My branch has been updated with the latest PathArea which has the offset fix.
herbk
Postby herbk » Thu May 18, 2017 5:24 pm
sliptonic wrote:My branch has been updated with the latest PathArea which has the offset fix.
Hi sliptonic,
do you know: is it merget to master (daily) also? I don't think so...
Gruß Herbert
sliptonic
Postby sliptonic » Thu May 18, 2017 6:43 pm
Hi sliptonic,
No. It's not ready yet. Still chasing bugs out.
roivai
Postby roivai » Fri Jun 16, 2017 8:35 am
I used PathContour with master from this morning and noticed that the contour path did not include a return to safe/clearance height after completing the finish depth. After running through linuxcnc post processor, the end of the code looks like this:
G3 X12.7268 Y12.7268 Z1.0000 I-1.3908 J17.9446 F480.0000
G1 X12.7268 Y12.7268 Z0.0000 F120.0000
G3 X-1.3908 Y17.9446 Z0.0000 I-12.7268 J-12.7268 F480.0000
G3 X1.3908 Y-17.9446 Z0.0000 I1.3908 J-17.9446 F480.0000
G3 X12.7268 Y12.7268 Z0.0000 I-1.3908 J17.9446 F480.0000
(finish operation: Contour)
(begin postamble)
M05
G00 X-1.0 Y1.0
G17 G90
M2
This will crash to tool because that position (-1,1) is in the middle of the part.
I suppose this is sort of a bug??
berka
Postby berka » Fri Jun 16, 2017 1:04 pm
@roival,
I found the same issue (luckily) in simulation -- big cut slashing through the part.
G0 Z<safe> is missing.
In my case, I followed it back:
It isn't generated in the contour operation, so
it's missing from my holding tags dress-up, so
it's missing from the post-processed output.
Note: the final G0 to (-1,1) is added at the post processor. (I'm not sure why they didn't chose to return to (0,0).)
sliptonic
Postby sliptonic » Fri Jun 16, 2017 1:27 pm
looks like a bug to me. Please try this:
Add this at line 265 in PathContour.py
        # Let's finish by rapid to clearance...just for safety
        commandlist.append(Path.Command("G0", {"Z": obj.ClearanceHeight.Value}))
