I was milling only using Gcode from FreeCad but allways the male piece does not fit on the female piece then looking to the path generated i saw that the last line isnt at 3mm from the begining of milling job. Z(0) the step down is 0.5 i allways get 2.5 mm from Z0, even if the step down is 1 mm i get 2mm from Z0
Look at Job 002..
Sorry about my poor English ..
Path pocket from Object base Bug
- new_lipo.fcstd
- (578.94 KiB) Downloaded 61 times
Re: Path pocket from Object base Bug
I have the feeling this is related to https://forum.freecadweb.org/viewtopic.php?f=15&t=23492. If I make the 3mm box you subtract slightly bigger than 3mm and offset it accordingly I get the same coplanar exception.
- sliptonic
If you're building from source, could you please try with this branch: https://github.com/sliptonic/FreeCAD/tree/bug/pocketbug
Did not work for me .. i bought a windows program to move forward .. DeskProto.. but i'm waiting for the solution, because i love Linux / Mac .sliptonic wrote: ↑Tue Aug 01, 2017 2:57 pm If you're building from source, could you please try with this branch: https://github.com/sliptonic/FreeCAD/tree/bug/pocketbug
