CAM simulation for the Path Workbench
shaise
Postby shaise » Fri Sep 15, 2017 11:38 am
Hi Sliptonic, mlampert and Yorik
First of all, my deepest thanks for the path workbench!
I was long looking for a good opensource CAM software, and now I have it integrated to my favorite CAD software.
I wanted to ask if there is any WIP regarding a CAM simulation functionality. If not, I want to try and contribute to this subject.
I have already made a preliminary macro that takes a job and simulate the milling on the stock object:
Right now it is in a very early stage, and I will soon post it on github. Hopefully if it will be mature enough, it can be
integrated into the Path Workbench.
The main issue with it is performance (boolean operations are rather slow) but in many cases its worth the wait, to make sure our gcode is correct.
I will probably need some help from the community, please let me know the correct forum section to post questions.
Right now, I'm looking for documentation/sample code for animating the process with a way to cancel in the middle (as now it hangs FreeCAD till operation is done)
ickby
Re: CAM simulation for the Path Workbench
Postby ickby » Fri Sep 15, 2017 11:51 am
I have not mut knowledge, but I think some CAM simulations works with voxels. OCC has some basic support for that, so this may be something you can experiment with to increase speed and maybe even achieve simulation:
https://www.opencascade.com/doc/occt-6. ... ls_wp.html
shaise
Postby shaise » Fri Sep 15, 2017 3:30 pm
Thanks!
Indeed voxels is the fastest way. It seems that OCC visualization of voxels is not that good, but it is definitely a path I will explore.
shai
Postby Kunda1 » Fri Sep 15, 2017 4:10 pm
shaise
Postby shaise » Fri Sep 15, 2017 5:25 pm
Cute workbench... :)
Another issue with voxels is that to get good resolution, we need lots of voxels (hundreds of Megs), meaning lots
of memory
mlampert
Postby mlampert » Fri Sep 15, 2017 6:23 pm
This is absolutely the direction we want to go, and one of the major reasons why we introduced the stock solid as a fixed part of each job recently. I know sliptonic did some work in this direction. I like your preliminary results, they look awesome! :D
sliptonic
Postby sliptonic » Fri Sep 15, 2017 8:56 pm
I'll second mlampert here. I'm thrilled to see some work in this area.
'Simulation' is one of those terms that's used to mean a bunch of different things so I'd welcome some discussion about exactly what you mean and the order/priority for developing parts of it. For example,
Simulating the movement of the cutter through the material (animation) is really useful to visualize the job operation order. As noted, it's quite resource intensive.
Simulating the resulting stock (like your screenshot) is also good for this. But if the shapes are accurate enough, they can also be used as input for refinement operations and detecting intersections with the model (gouging). That's much more important to me so I'd set it as higher priority.
Simulating the movement of the entire machine would just look really cool :D
shaise
Postby shaise » Fri Sep 15, 2017 9:13 pm
Hi Sliptonic,
Once again thanks for the great work!
Right now what I have is working only on contour paths with flat endmill
Here is what I plan next:
First of all make it animated. Not only for visualizing but to be able to cancel the (long) action. I will then post it on github.
Next I want it to work on other path types
Next, one by one I will support other tool shapes.
Next, Have a gui to control the operation (use other stock, do only partial work, etc)
Last, add feature requests by the community
shai
shaise
Postby shaise » Sat Sep 16, 2017 12:50 pm
Hi All,
I have managed to integrate some animation and control for the simulation:
https://youtu.be/iCe1zBoTb1I
shai
mlampert
Postby mlampert » Sat Sep 16, 2017 4:40 pm
nice, 'could watch it all day long :)
