Couple of potential bugs...
JoshM
Re: Couple of potential bugs...
Postby JoshM » Fri Dec 01, 2017 4:18 pm
Drilling and Helix operations seem to have been disabled in latest updates. I no longer get any dialog for either Op now.
Best,
Josh
Version: 0.17.12703 (Git)
Hash: e7d4296b2918f4ab939b9d425347d8fa5833de5b
Python version: 2.7.8
OCC version: 7.1.0
roivai
Postby roivai » Sat Dec 02, 2017 10:22 am
Best,
Josh
Oh crap, seems so. It clearly relates to changes I made last time, but something else as well because I'm 100% they worked multiple builds after that edit. I'll try to figure out what's going on right away. Thanks for pointing out.
roivai
Postby roivai » Sat Dec 02, 2017 1:10 pm
So the error thrown is:
'ObjectDrilling' object has no attribute 'baseobject'
Which means that the initialization of obj.baseobject is not done at the point where I added that call to findAllHoles()-function. The operations work if I simply add obj.recompute() before calling that. I haven't been studying the code after the major refactoring of PathOp related stuff, so I am quite lost there. So I don't know why the recompute is required there or is that the best way to clear this problem. @mlampert what do you think?
For anyone willing to fix it right now, the Create() function on the end of file PathDrilling.py and PathHelix.py should be modified to contain obj.recompute() like so:
def Create(name):
    '''Create(name) ... Creates and returns a Helix operation.'''
    obj = FreeCAD.ActiveDocument.addObject("Path::FeaturePython", name)
    proxy = ObjectHelix(obj)
    if obj.Proxy:
        obj.recompute()
        proxy.findAllHoles(obj)
    return obj
Another thing I noticed is that on the Base Location tab, pressing Add and manually writing the coordinates or pressing Edit and trying to modify existing location does not work. I need to go right now, so I couldn't investigate this at all..
mlampert
Postby mlampert » Sat Dec 02, 2017 1:42 pm
Interesting I moved the initialization of Proxy to the end of init in order to deal with the situation where the user hits cancel when selecting a tool (hence the if clause in Create). Once Proxy gets assigned the framework automatically calls execute - I found no way to prevent that, which is why Proxy is now assigned conditionally.
I'm surprised recompute changes anything which basically just calls execute for all dirty objects.
mlampert
Postby mlampert » Sat Dec 02, 2017 7:00 pm
It seems that behaviour changed - assigning Proxy doesn't trigger a call to execute anymore.
Edit: PR-1134
Joel Stienlet
Postby Joel Stienlet » Sun Dec 03, 2017 10:15 am
The circular hole bug seems solved with fix 1134, but I still have some strange thing:
PathOpGui.INFO: Title: 'Drilling'
Drilling Select Mode
PathCircularHoleBase.ERROR: Feature Base-Body.Face8 cannot be processed as a circular hole - please remove from Base geometry list.
PathDrilling(77).circularHoleExecute()
-> this is the bottom of a pocket created from a circle in a sketch, I think it should be a valid selection for creating a circular hole.
mlampert
Postby mlampert » Sun Dec 03, 2017 12:07 pm
could you attach the file so we can have a look?
Joel Stienlet
Postby Joel Stienlet » Sun Dec 03, 2017 12:25 pm
I've created a minimal file that gives me this this error (with fix 1134):
https://drive.google.com/open?id=1HgcbG ... 4mw4GflJ2m
the error is triggered when I click on "OK" ok "Apply" when creating the drilling.
Postby chrisb » Sun Dec 03, 2017 12:55 pm
You try to drill a 1.535mm hole with a 5mm tool :o . That won't work
Joel Stienlet
Postby Joel Stienlet » Sun Dec 03, 2017 1:27 pm
Sorry, I should have set a correct diameter, this was misleading. So I uploaded a new file, this time the diameters should be correct (I hope so, 3mm diameter drill for a +-3mm diameter hole):
https://drive.google.com/open?id=1hCLvT ... Thn6uG3BhW
Anyway, the error message "Feature Base-Body.Face8 cannot be processed as a circular hole - please remove from Base geometry list" seems not to refer to a diameter mismatch I think.
N.B. a reasonable mismatch between tool and theoretical diameter should be allowed I think, as you don't always have the precise tool in the shop. Not everybody has anyway. And sometimes larger is better than smaller (ex: through hole component in a PCB). The best would be to specify tolerances +- while defining the geometry, and then check if the tool matches these tolerances. I don't know if there's something like this, I'm still new at FreeCAD, I haven't tested all the features yet...
