First of all, congratulations to all developers .
I Have some problems to edit where the tagdressups are in a profile_faces.
Version: 0.17.12431 (Git)
Hash: c397aee9ed3efcb2e33fa719313c98cc4867cf32
Python version: 2.7.8
OCC version: 7.1.0
Can't edit TagDressup
Re: Can't edit TagDressup
thank you for correcting the bug.
Path: Bugfix/tags snapper fix (#1067)
Took a bit of digging, but I think it works better now than it ever did before - Thanks for reporting and patience!
It looks like there may still be some lingering issues.
- I can't get the auto Generate to work. When I press the "Replace All" button I get two different results on two designs. One: nothing. Other: apparently nothing, but if OK and re-enter the dialog, I get the auto-generated tags.
- I have a design where no matter what I do, I couldn't enable the tags any more. After OK out of dialog, they just get disabled.
OS: Mac OS X
Version: 0.17.12613 (Git)
Branch: (HEAD detached at c770ce7)
Hash: c770ce7a343072dd2df74bf5b95ac4a114ce9213
Python version: 2.7.14
Qt version: 5.6.2
OCC version: 7.1.0
- TestBottomPocket.FCStd
- (48.93 KiB) Downloaded 67 times
PR-1106 should fix the issue. I've had no problems with your file, please give it a try.
Thanks. Autogenerate works now. I didn't try the manual add/removes; I didn't have to.
Autogenerate works.
Adding or editing a tag by clicking on the path works.
Adding or editing a tag by editing the values in the combo box does not work, even if coordinates are precisely on the path (not sure whether values like 1 mm or 7 mm can raise rounding errors).
If the height of a tag coincides with the path one level above, the tag might become (randomly?) deactivated. Having it 0.1 mm below or above will not cause that behavior – all that "in my case", YMMV.
Oliver
OS: Windows 7
Word size of FreeCAD: 32-bit
Version: 0.17.12703 (Git)
Hash: e7d4296b2918f4ab939b9d425347d8fa5833de5b
OCC version: 7.0.0
(yes, I do use FreeCAD on at least three different systems)
Oliver
OS: Windows 7
OCC version: 7.0.0
- Stringer.FCStd
- (23.24 KiB) Downloaded 49 times
