Toolcontroller GUI Bug
since the height-depth-rewrite the tool-controller GUI in FreeCAD-daily is a little bit broken
Bye
Thorsten
Bye
Thorsten
Re: Toolcontroller GUI Bug
works for me
OS: Debian GNU/Linux testing (buster)
Version: 0.17.12620 (Git)
Build type: Debug
Hash: 99a2fd16f47f11c1e8d404d3e193e8747c41820d
Python version: 2.7.14
OCC version: 7.2.0
Thorsten,
May I ask your naming convention for your Tool-Controller. I'm assuming that's an 8mm diameter, 25mm cut-length. Is ALU a coating, or intended material? Do you separate between tool styles in your names? I ask because I'm trying to determine best approach for myself.
Best,
Josh
Best,
Josh
@JoshM
Yes, its diameter-#Tooth-cutting_length-intended_material
I use this scheme for end mills.
Face mills and bullnose mills start with a textual label.
This is just works-for-me stuff
Bye
Thorsten
Bye
Thorsten
Same problem for me on Mac.
OS: Mac OS X
Version: 0.17.12619 (Git)
Branch: (HEAD detached at b3631e1)
Hash: b3631e134be8bfade0534f2dc0ee668ae71a223f
Qt version: 5.6.2
OCC version: 7.1.0
Locale: French/France (fr_FR)
OS: Mac OS X
Qt version: 5.6.2
OCC version: 7.1.0
https://github.com/Xav83130/Mini-CNC
Tuto FR-basic -PATH - https://github.com/Xav83130/Mini-CNC/wi ... Basic-Path (plus a jour)
@mlampert
But in Designer the horizontal size policy of
FreeCAD-master/src/Mod/Path/Gui/Resources/panels/DlgToolControllerEdit.ui
is set to minimum(?)
BTW
OS: Ubuntu 14.04.5 LTS
Build type: None
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
Build type: None
Qt version: 4.8.6
OCC version: 7.1.0
Thank you @Throsten--appreciate your perspective and experience!
Best Regards,
Josh
Can you change the policy and see what happens? (you need to recompile for the change to take)
Unfortunately I can't reproduce.
If I change to "expand" everything is fine in designer preview
HTH
Thorsten
HTH
Thorsten
