GRBL new post processor with drill cycles G81..G83
Re: GRBL new post processor with drill cycles G81..G83
No need to hack the source files, you can set it in the Job Edit dialogue, where you set the post processor to use :
- grbl-opts.png (36.7 KiB) Viewed 3399 times
Oh awesome, that's even better!
Thanks.
Is there a list of arguments and their functions somewhere?
Thanks.
For a list, read where it is defined in grbl_post.py
I think most are fairly self explanatory. I don't know of any doc, but that would not mean there isn't any.
Gotcha, cheers.
I'm no programmer so I've no idea how the translation from "TRANSLATE_DRILL_CYCLES = True" to "--translate_drill" comes about.
If you have the time and inclination to explain, that'd be cool. If not, then I'll just accept it and move on.
# Parser arguments list & definition
parser = argparse.ArgumentParser(prog='grbl', add_help=False)
parser.add_argument('--comments', action='store_true', help='output comment (default)')
parser.add_argument('--no-comments', action='store_true', help='suppress comment output')
parser.add_argument('--header', action='store_true', help='output headers (default)')
parser.add_argument('--no-header', action='store_true', help='suppress header output')
parser.add_argument('--line-numbers', action='store_true', help='prefix with line numbers')
parser.add_argument('--no-line-numbers', action='store_true', help='don\'t prefix with line numbers (default)')
parser.add_argument('--show-editor', action='store_true', help='pop up editor before writing output (default)')
parser.add_argument('--no-show-editor', action='store_true', help='don\'t pop up editor before writing output')
parser.add_argument('--precision', default='3', help='number of digits of precision, default=3')
parser.add_argument('--translate_drill', action='store_true', help='translate drill cycles G81, G82 & G83 in G0/G1 movements')
parser.add_argument('--no-translate_drill', action='store_true', help='don\'t translate drill cycles G81, G82 & G83 in G0/G1 movements (default)')
parser.add_argument('--preamble', help='set commands to be issued before the first command, default="G17 G90"')
parser.add_argument('--postamble', help='set commands to be issued after the last command, default="M5\nG17 G90\n;M2"')
parser.add_argument('--inches', action='store_true', help='Convert output for US imperial mode (G20)')
parser.add_argument('--tool-change', action='store_true', help='Insert M6 for all tool changes')
parser.add_argument('--wait-for-spindle', type=int, default=0, help='Wait for spindle to reach desired speed after M3 / M4, default=0')
parser.add_argument('--return-to', default='', help='Move to the specified coordinates at the end, e.g. --return-to=0,0')
parser.add_argument('--bcnc', action='store_true', help='Add Job operations as bCNC block headers. Consider suppressing existing comments: Add arg>
parser.add_argument('--no-bcnc', action='store_true', help='suppress bCNC block header output (default)')
TOOLTIP_ARGS = parser.format_help()
You get the actual option arguments that you can type in with a brief explanation of what they do and what the default state is.
If you click to put the text cursor in input box it does not show unless move the mouse a little and hover after clicking. If you hover without clicking you get it. At least that is what my Linux UI does. If it popped up when you click to type, I guess it would get in the way.
Anyway , that's probably what you wanted to know.
Yup, that's exactly what I was after.
Thanks once again
Thanks once again
Without going into the code you can go over the input field and the help text popping up shows the parameters.
For me it doesn't
OS: Windows 10 Version 2009
Version: 0.20.25645 (Git)
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/New Zealand (en_NZ)
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
- New Bitmap Image.jpg (115.74 KiB) Viewed 3118 times
No, I said the Job Edit dialogue, not preferences. Look at the screen shot here:
https://forum.freecadweb.org/viewtopic. ... 87#p542028
Hover on where you see "Arguments" input box where you can type in --translate_drill or other option arguments.
Ah you mean here...........
That works.
Would be great to have the same popup in the preferences area to be able to set it as a default, rather than a job by job basis.
I guess if all the arguments you want are in there then you save that as your template that works too.
EDIT: It seems that what's in your template overwrites what's in your preferences anyway eg output file name and location.
Thanks again for the help everyone.
That works.
- New Bitmap Image.jpg (167.78 KiB) Viewed 3097 times
