Yes, a post processor preferences and options panel is a good idea.
I've solved the situation for my case by modifying the source since I'm building it. But a more general solution would be good.
I'm not entirely sure what you are meaning by that comment but it sounds like you are saying what Gautier suggested is already present.
If you would have cared to open up the preferences before getting on your soap box you might have noticed the path output section. But I guess that's too much to ask for these days. Also, I have pointed at the job templates several times before which can also specify the post processor - which can also be set in the preferences. Can't help ya if ya ain't using what's there.freman wrote: ↑Sat Oct 26, 2019 7:04 pmI'm not entirely sure what you are meaning by that comment but it sounds like you are saying what Gautier suggested is already present.
He was suggesting an options panel ( presumably a kind of checkbox thing for the binary choice options ) . At the moment, all there is an edit box where you can type in kind of command line option. You need to continually configure this every time you create a job which is quite a drag.
I even find continually needing to select my post processor on every single job a drag. There is little chance I'm flipping constantly from one machine to another needing different PPs each time. Pre-filling the choice with the last used PP would be a nice trivial feature mod that would make the work flow easier. If any typed options could also be made persistent that would get around some of the need for a panel ( though not having to dig around to find the exact text required would still be a plus for a gui approach ).
I was not "getting on my soapbox" I was trying to make a useful suggestion where I thought improvements could be made. I did look at prefs but due to screen size ( I only have 1780x 1240 availablemlampert wrote: ↑Sat Oct 26, 2019 9:58 pm
File "~/freecad-master-build/Mod/Path/PathScripts/PathPreferencesPathJob.py", line 262, in setProcessorListTooltip
self.setPostProcessorTooltip(self.form.postProcessorList, item.text(), '')
File "~/freecad-master-build/Mod/Path/PathScripts/PathPreferencesPathJob.py", line 255, in setPostProcessorTooltip
processor = self.getPostProcessor(name)
File "~/freecad-master-build/Mod/Path/PathScripts/PathPreferencesPathJob.py", line 249, in getPostProcessor
processor = PostProcessor.load(name)
File "~/freecad-master-build/Mod/Path/PathScripts/PathPostProcessor.py", line 49, in load
exec("import %s as current_post" % postname, namespace) # pylint: disable=exec-used
File "~/freecad-master-build/Mod/Path/PathScripts//post/centroid_post.py", line 82, in <module>
'''.format(__name__, FreeCAD.ActiveDocument.FileName, str(now))
AttributeError: 'NoneType' object has no attribute 'FileName'
(Exported by FreeCAD)
(Post Processor: grbl_post)
(Output Time:2020-01-06 12:13:27.479520)
(begin preamble)
G17 G90
G21
(begin operation: T1: 5mm_3flute_endmill_45degree)
(Path: T1: 5mm_3flute_endmill_45degree)
(T1: 5mm_3flute_endmill_45degree)
(begin toolchange)
; M6 T2
M3 S1500.0000
(finish operation: T1: 5mm_3flute_endmill_45degree)
(begin operation: Drilling)
(Path: Drilling)
(Drilling)
(Begin Drilling)
G0 Z19.0000
G90
; G98
G83 X7.5000 Y6.5000 Z0.0000 F6.00 Q0.3000 R0.1000
; G80
G0 Z19.0000
(finish operation: Drilling)
(begin postamble)
M5
G17 G90
; M2
(Post Processor: grbl_G81_post)
(Output Time:2020-01-06 12:41:29.001765)
(begin preamble)
G17 G90
G21
(begin toolchange)
(M6 T2.0)
M3 S1500.000
(Path: Drilling)
(Drilling)
(Begin Drilling)
G0 Z19.000
G90
(G98)
(G83 X7.500 Y6.500 Z0.000 F6.00 Q0.300 R0.100)
G0 X7.500 Y6.500
G1 Z18.700 F6.00
G0 Z19.000
G1 Z18.400 F6.00
G0 Z19.000
G1 Z18.100 F6.00
G0 Z19.000
G1 Z17.800 F6.00
G0 Z19.000
G1 Z17.500 F6.00
G0 Z19.000
G1 Z17.200 F6.00
G0 Z19.000
G1 Z16.900 F6.00
G0 Z19.000
G1 Z16.600 F6.00
G0 Z19.000
G1 Z16.300 F6.00
G0 Z19.000
G1 Z16.000 F6.00
G0 Z19.000
G1 Z15.700 F6.00
G17 G90
G21
(begin toolchange)
(M6 T2.0)
M3 S1500.000
(Path: Drilling)
(Drilling)
(Begin Drilling)
G0 Z19.000
G90
G99
G0 X7.500 Y6.500
G0 Z19.000
G1 Z0.000 F6.00
G0 Z0.100
(G80)
G0 Z19.000
(begin postamble)
M5
G17 G90
M2
(Post Processor: grbl_G83_post)
(Output Time:2020-01-07 00:38:33.770124)
(begin preamble)
G17 G90
G21
(begin toolchange)
(M6 T2.0)
M3 S1500.000
(Path: Drilling)
(Drilling)
(Begin Drilling)
G0 Z19.000
G90
(G99)
G0 X7.500 Y6.500
G1 Z18.700 F6.00
G0 Z18.800
G1 Z18.400 F6.00
G0 Z18.500
G1 Z18.100 F6.00
G0 Z18.200
G1 Z17.800 F6.00
G0 Z17.900
G1 Z17.500 F6.00
G0 Z17.600
G1 Z17.200 F6.00
G0 Z17.300
# -*- coding: utf-8 -*-
#* (c) Gauthier Briere - 2018 *
#* (c) Simon Merrett - 2020 *
#* This program is free software; you can redistribute it and/or modify *
#* it under the terms of the GNU Lesser General Public License (LGPL) *
#* as published by the Free Software Foundation; either version 2.1 of *
#* the License, or (at your option) any later version. *
#* for detail see the LICENSE text file. *
#* This program is distributed in the hope that it will be useful, *
#* but WITHOUT ANY WARRANTY; without even the implied warranty of *
#* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
#* GNU Lesser General Public License for more details. *
#* You should have received a copy of the GNU Library General Public *
#* License along with This program; if not, write to the Free Software *
#* Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 *
#* USA *
TOOLTIP='''
Generate g-code from a Path that is compatible with the grbl controller.
import grbl_post
grbl_post.export(object, "/path/to/file.ncc")
import FreeCAD
import PathScripts.PostUtils as PostUtils
import argparse
import datetime
import shlex
# Globals set customization preferences
# Default values for command line arguments:
OUTPUT_COMMENTS = True # default output of comments in output gCode file
OUTPUT_HEADER = True # default output header in output gCode file
OUTPUT_LINE_NUMBERS = False # default doesn't output line numbers in output gCode file
SHOW_EDITOR = True # default show the resulting file dialog output in GUI
PRECISION = 3 # Default precision for metric (see http://linuxcnc.org/docs/2.7/html/gcode/overview.html#_g_code_best_practices)
TRANSLATE_DRILL_CYCLES = True # If true, G81, G82 & G83 are translated in G0/G1 moves
PREAMBLE = '''G17 G90
''' # default preamble text will appear at the beginning of the gCode output file.
POSTAMBLE = '''M5
G17 G90
M2
''' # default postamble text will appear following the last operation.
# Customisation with no command line argument
MODAL = False # if true commands are suppressed if the same as previous line.
LINENR = 100 # line number starting value
LINEINCR = 10 # line number increment
OUTPUT_TOOL_CHANGE = False # default don't output M6 tool changes (comment it) as grbl currently does not handle it
DRILL_RETRACT_MODE = 'G98' # Default value of drill retractations (CURRENT_Z) other possible value is G99
MOTION_MODE = 'G90' # G90 for absolute moves, G91 for relative
UNITS = 'G21' # G21 for metric, G20 for us standard
SPEED_MULTIPLIER = 60 # *60 convert FreeCAD's mm/s to mm/mn
PRE_OPERATION = '''''' #Pre operation text will be inserted before every operation
POST_OPERATION = '''''' #Post operation text will be inserted after every operation
TOOL_CHANGE = '''''' #Tool Change commands will be inserted before a tool change
# End of customization
# Parser arguments list & definition
parser = argparse.ArgumentParser(prog='grbl_G81', add_help=False)
parser.add_argument('--comments', action='store_true', help='output comment (default)')
parser.add_argument('--no-comments', action='store_true', help='suppress comment output')
parser.add_argument('--header', action='store_true', help='output headers (default)')
parser.add_argument('--no-header', action='store_true', help='suppress header output')
parser.add_argument('--line-numbers', action='store_true', help='prefix with line numbers')
parser.add_argument('--no-line-numbers', action='store_true', help='don\'t prefix with line numbers (default)')
parser.add_argument('--show-editor', action='store_true', help='pop up editor before writing output (default)')
parser.add_argument('--no-show-editor', action='store_true', help='don\'t pop up editor before writing output')
parser.add_argument('--precision', default='3', help='number of digits of precision, default=3')
parser.add_argument('--translate_drill', action='store_true', help='translate drill cycles G81, G82 & G83 in G0/G1 movements (default)')
parser.add_argument('--no-translate_drill', action='store_true', help='don\'t translate drill cycles G81, G82 & G83 in G0/G1 movements')
parser.add_argument('--preamble', help='set commands to be issued before the first command, default="G17 G90"')
parser.add_argument('--postamble', help='set commands to be issued after the last command, default="M5\nG17 G90\n;M2"')
TOOLTIP_ARGS=parser.format_help()
# Internal global variables
MOTION_COMMANDS = ['G0', 'G00', 'G1', 'G01', 'G2', 'G02', 'G3', 'G03'] # Motion gCode commands definition
RAPID_MOVES = ['G0', 'G00'] # Rapid moves gCode commands definition
SUPPRESS_COMMANDS = ['G99', 'G98', 'G80'] #COMMIT DOCS added 'G99' to SUPPRESS_COMMANDS to fix error in unfolding G83 cycle # These commands are ignored by commenting them out
COMMAND_SPACE = " "
CURRENT_X = 0 # Global variable storing current position
CURRENT_Y = 0
CURRENT_Z = 0
# to distinguish python built-in open function from the one declared below
if open.__module__ in ['__builtin__','io']:
pythonopen = open
def processArguments(argstring):
global OUTPUT_HEADER
global OUTPUT_COMMENTS
global OUTPUT_LINE_NUMBERS
global SHOW_EDITOR
global PRECISION
global PREAMBLE
global POSTAMBLE
global TRANSLATE_DRILL_CYCLES
try:
args = parser.parse_args(shlex.split(argstring))
if args.no_header:
OUTPUT_HEADER = False
if args.header:
if args.no_comments:
OUTPUT_COMMENTS = False
if args.comments:
if args.no_line_numbers:
if args.line_numbers:
OUTPUT_LINE_NUMBERS = True
if args.no_show_editor:
SHOW_EDITOR = False
if args.show_editor:
SHOW_EDITOR = True
PRECISION = args.precision
if args.preamble is not None:
PREAMBLE = args.preamble
if args.postamble is not None:
POSTAMBLE = args.postamble
if args.no_translate_drill:
TRANSLATE_DRILL_CYCLES = False
if args.translate_drill:
except:
return False
return True
# For debug...
def dump(obj):
for attr in dir(obj):
print("obj.%s = %s" % (attr, getattr(obj, attr)))
def export(objectslist, filename, argstring):
if not processArguments(argstring):
return None
global UNITS
global MOTION_MODE
print("Post Processor: " + __name__ +" postprocessing...")
gcode = ""
# write header
if OUTPUT_HEADER:
gcode += linenumber() + "(Exported by FreeCAD)\n"
gcode += linenumber() + "(Post Processor: " + __name__ +")\n"
gcode += linenumber() + "(Output Time:"+str(datetime.datetime.now())+")\n"
# Write the preamble
if OUTPUT_COMMENTS:
gcode += linenumber() + "(begin preamble)\n"
for line in PREAMBLE.splitlines(True):
gcode += linenumber() + line
# verify if PREAMBLE have changed MOTION_MODE or UNITS
if 'G90' in PREAMBLE:
MOTION_MODE = 'G90'
elif 'G91' in PREAMBLE:
MOTION_MODE = 'G91'
else:
gcode += linenumber() + MOTION_MODE + "\n"
if 'G21' in PREAMBLE:
UNITS = 'G21'
elif 'G20' in PREAMBLE:
UNITS = 'G20'
else:
gcode += linenumber() + UNITS + "\n"
for obj in objectslist:
# Debug...
#print("\n" + "*"*70)
#dump(obj)
#print("*"*70 + "\n")
if not hasattr(obj,"Path"):
print("The object " + obj.Name + " is not a path. Please select only path and Compounds.")
return
# do the pre_op
if OUTPUT_COMMENTS: gcode += linenumber() + "(begin operation: " + obj.Label + ")\n"
for line in PRE_OPERATION.splitlines(True):
# Parse the op
gcode += parse(obj)
# do the post_op
if OUTPUT_COMMENTS: gcode += linenumber() + "(finish operation: " + obj.Label + ")\n"
for line in POST_OPERATION.splitlines(True):
#do the post_amble
if OUTPUT_COMMENTS: gcode += linenumber() + "(begin postamble)\n"
for line in POSTAMBLE.splitlines(True):
#show the gCode result dialog
if FreeCAD.GuiUp and SHOW_EDITOR:
dia = PostUtils.GCodeEditorDialog()
dia.editor.setText(gcode)
result = dia.exec_()
if result:
final = dia.editor.toPlainText()
else:
final = gcode
else:
final = gcode
print("done postprocessing.")
#write the file
gfile = pythonopen(filename,"w")
gfile.write(gcode)
gfile.close()
def linenumber():
global LINENR
global LINEINCR
if OUTPUT_LINE_NUMBERS == True:
s = "N" + str(LINENR) + " "
LINENR += LINEINCR
return s
return ""
def format_outstring(strTbl):
global COMMAND_SPACE
# construct the line for the final output
s = ""
for w in strTbl:
s += w + COMMAND_SPACE
s = s.strip()
return s
def parse(pathobj):
global DRILL_RETRACT_MODE
global MOTION_MODE
global CURRENT_X
global CURRENT_Y
global CURRENT_Z
out = ""
lastcommand = None
precision_string = '.' + str(PRECISION) +'f'
params = ['X','Y','Z','A','B','C','I','J','K','F','S','T','Q','R','L','P']
if hasattr(pathobj,"Group"): # We have a compound or project.
if OUTPUT_COMMENTS: out += linenumber() + "(compound: " + pathobj.Label + ")\n"
for p in pathobj.Group:
out += parse(p)
return out
else: # parsing simple path
if not hasattr(pathobj,"Path"): #groups might contain non-path things like stock.
return out
if OUTPUT_COMMENTS: out += linenumber() + "(Path: " + pathobj.Label + ")\n"
for c in pathobj.Path.Commands:
outstring = []
command = c.Name
outstring.append(command)
# if modal: only print the command if it is not the same as the last one
if MODAL == True:
if command == lastcommand:
outstring.pop(0)
# Now add the remaining parameters in order
for param in params:
if param in c.Parameters:
if param == 'F':
if command not in RAPID_MOVES:
outstring.append(param + format(c.Parameters['F'] * SPEED_MULTIPLIER, '.2f'))
elif param == 'T':
outstring.append(param + str(c.Parameters['T']))
else:
outstring.append(param + format(c.Parameters[param], precision_string))
# store the latest command
lastcommand = command
# Memorise la position courante pour calcul des mouvements relatis et du plan de retrait
if command in MOTION_COMMANDS:
if 'X' in c.Parameters:
CURRENT_X = c.Parameters['X']
if 'Y' in c.Parameters:
CURRENT_Y = c.Parameters['Y']
if 'Z' in c.Parameters:
CURRENT_Z = c.Parameters['Z']
if command in ('G98', 'G99'):
DRILL_RETRACT_MODE = command
if command in ('G90', 'G91'):
MOTION_MODE = command
if TRANSLATE_DRILL_CYCLES:
if command in ('G81', 'G82', 'G83'):
out += drill_translate(outstring, command, c.Parameters)
# Efface la ligne que l'on vient de translater
del(outstring[:])
outstring = []
# Check for Tool Change:
if command in ('M6', 'M06'):
if OUTPUT_COMMENTS: out += linenumber() + "(begin toolchange)\n"
if not OUTPUT_TOOL_CHANGE:
outstring[0] = "(" + outstring[0]
outstring[-1] = outstring[-1] + ")"
else:
for line in TOOL_CHANGE.splitlines(True):
out += linenumber() + line
if command == "message":
if OUTPUT_COMMENTS == False:
out = []
else:
outstring.pop(0) #remove the command
if command in SUPPRESS_COMMANDS:
#prepend a line number and append a newline
if len(outstring) >= 1:
out += linenumber() + format_outstring(outstring) + "\n"
return out
def drill_translate(outstring, cmd, params):
global MOTION_MODE
global CURRENT_X
global CURRENT_Y
global CURRENT_Z
strFormat = '.' + str(PRECISION) +'f'
trBuff = ""
if OUTPUT_COMMENTS: # Comment the original command
trBuff += linenumber() + format_outstring(outstring) + "\n"
# Conversion du cycle
# Pour l'instant, on gere uniquement les cycles dans le plan XY (G17)
# les autres plans ZX (G18) et YZ (G19) ne sont pas traites : Calculs sur Z uniquement.
if MOTION_MODE == 'G90': # Deplacements en coordonnees absolues
drill_X = params['X']
drill_Y = params['Y']
drill_Z = params['Z']
RETRACT_Z = params['R'] #RETRACT_Z_SMALL = params['R'] # added in the mod to enable small retracts with G83
else: # G91 Deplacements relatifs
drill_X = CURRENT_X + params['X']
drill_Y = CURRENT_Y + params['Y']
drill_Z = CURRENT_Z + params['Z']
RETRACT_Z = CURRENT_Z + params['R']
if DRILL_RETRACT_MODE == 'G98' and CURRENT_Z >= RETRACT_Z:
# Recupere les valeurs des autres parametres
drill_Speed = params['F'] * SPEED_MULTIPLIER
if cmd == 'G83':
drill_Step = params['Q']
elif cmd == 'G82':
drill_DwellTime = params['P']
if MOTION_MODE == 'G91':
trBuff += linenumber() + "G90" + "\n" # Force des deplacements en coordonnees absolues pendant les cycles
#COMMIT DOCS Don't think this applies to G99 so propose a conditional. Don't know what to do for safe height move though, or even if that's needed
# Mouvement(s) preliminaire(s))
if CURRENT_Z < RETRACT_Z and DRILL_RETRACT_MODE == 'G98': #COMMIT DOCS added condition
trBuff += linenumber() + 'G0 Z' + format(RETRACT_Z, strFormat) + "\n"
trBuff += linenumber() + 'G0 X' + format(drill_X, strFormat) + ' Y' + format(drill_Y, strFormat) + "\n"
if CURRENT_Z > RETRACT_Z and DRILL_RETRACT_MODE == 'G98': #COMMIT DOCS added condition
trBuff += linenumber() + 'G0 Z' + format(CURRENT_Z, strFormat) + "\n"
# Mouvement de percage
if cmd in ('G81', 'G82'):
trBuff += linenumber() + 'G1 Z' + format(drill_Z, strFormat) + ' F' + format(drill_Speed, '.2f') + "\n"
# Temporisation eventuelle
if cmd == 'G82':
trBuff += linenumber() + 'G4 P' + str(drill_DwellTime) + "\n"
# Sortie de percage
else: # 'G83'
if DRILL_RETRACT_MODE == 'G98':#COMMIT DOCS added condition
next_Stop_Z = RETRACT_Z - drill_Step
elif DRILL_RETRACT_MODE == 'G99': #COMMIT DOCS added condition
next_Stop_Z = CURRENT_Z - drill_Step #COMMIT DOCS added alternative point#
while 1:
if next_Stop_Z > drill_Z:
trBuff += linenumber() + 'G1 Z' + format(next_Stop_Z, strFormat) + ' F' + format(drill_Speed, '.2f') + "\n"
if DRILL_RETRACT_MODE == 'G98': #COMMIT DOCS added condition
trBuff += linenumber() + 'G0 Z' + format(next_Stop_Z + RETRACT_Z, strFormat) + "\n" #COMMIT DOCS adapted retract height to match G99
next_Stop_Z -= drill_Step
else:
trBuff += linenumber() + 'G0 Z' + format(CURRENT_Z, strFormat) + "\n" #COMMIT DOCS adapted retract to original rapids height before drilling operation in Z
break
trBuff += linenumber() + 'G91' # Restore le mode de deplacement relatif
return trBuff
print(__name__ + ": gCode postprocessor loaded.")
