Feature request: Array for pathes with dressup
herbk
Post by herbk »
Hi, - and firstly a happy new year to all...
I need to mill out 8 peaces of a type of washer. Normaly if i have to do something like that, i draw only one part, make the path of it and from the path a array.
Different this time: The parts are very small and material is alu, so i want to use holding tags and a ramp entry dressup. I noticed, that ist not possible to make a array (or a copy) if i dressup is used.
So i have to make a array from my part first, than to create 2 to pathes of each part and set the dress-ups on each path manuelly...:cry:
For situations like that it would be a big help, if path array also works on pathes with a dressup.
OS: "openSUSE Leap 42.3"
Version: 0.17.12871 (Git) AppImage
Build type: None
Hash: 070395d67ca45826f1481da80aa9e0f6a9ef4292
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
Scheibe.fcstd
(116.54 KiB) Downloaded 79 times
Gruß Herbert
herbk
Re: Feature request: Array for pathes with dressup
Post by herbk »
Dear Path developers,
i dig out this old thread, because the behavior that i can't get a array or a copy of a path with a dressup is still there.
Is it still there or do i miss any thing?
A new example to show the problem: I need to mill out this 3 parts as often as it fits at the cube, which represents the peace of meterial where it's to cut out, also at this case i need to use ramp entry and holding tags.
Edit: The same behavior shows the option to copy a OP, if a dressup is applied at it, it's not possible to make a copy of it...
Gruß Herbert
herbk
Post by herbk »
I play'd around with the arrays and dressups and find aut several behaviors:
It's not possible to create a array or a copy of a path with an dressup, but it's possible to ad some, but not all, dressups to a Path Array.
At an Path Array
Dogbone Dressup works
Holding Tags Dressup works, but don't set tags automiticly like at a single path.
LeadInOut don't work, error message is:
  File "/tmp/.mount_FreeCAEDVzrs/usr/Mod/Path/PathScripts/PathDressupLeadInOut.py", line 103, in execute
    obj.Path = self.generateLeadInOutCurve(obj)
  File "/tmp/.mount_FreeCAEDVzrs/usr/Mod/Path/PathScripts/PathDressupLeadInOut.py", line 288, in generateLeadInOutCurve
    temp = self.getLeadStart(obj, queue, action)
  File "/tmp/.mount_FreeCAEDVzrs/usr/Mod/Path/PathScripts/PathDressupLeadInOut.py", line 161, in getLeadStart
    extendcommand = Path.Command('G0', {"X": 0.0, "Y": 0.0, "Z": op.ClearanceHeight.Value})
<class 'AttributeError'>: 'FeaturePython' object has no attribute 'ClearanceHeight'
2.71e-07 <App> Document.cpp(3455): Failed to recompute Unnamed#LeadInOutDressup: 'FeaturePython' object has no attribute 'ClearanceHeight'
Recompute failed! Please check report view.
RampEntry don't work, error message is:
Running the Python command 'Path_DressupRampEntry' failed:
  File "/tmp/.mount_FreeCAEDVzrs/usr/Mod/Path/PathScripts/PathDressupRampEntry.py", line 711, in Activated
    FreeCADGui.doCommand('dbo.setup(obj)')
  File "/tmp/.mount_FreeCAEDVzrs/usr/Mod/Path/PathScripts/PathDressupRampEntry.py", line 100, in setup
    if PathDressup.baseOp(obj).StartDepth is not None:
'FeaturePython' object has no attribute 'StartDepth'[<Path::FeaturePython object>, <Path::FeaturePython object>]
An other stupid thing i have since a while.. If i mark a piece of text at the Report View panel and use "ctrl c" to copy, a UI opens and the text isn't at copyd (can't put it in anywhere)
That's only if i'm at Path WB, at other WBs it works like expected.
OS: openSUSE Leap 15.1 (KDE//usr/share/xsessions/plasma5)
Version: 0.19.18403 (Git) AppImage
Hash: 0717b4fc23ef1db70964c3977d25e2fe46a739d1
Python version: 3.7.3
Qt version: 5.12.5
Gruß Herbert
tomi_wunder
Post by tomi_wunder »
I'd like to second this request as I just came across the same problem. I frequently need to machine a number of smaller parts out of a piece of plywood etc. Adding the holding tag dressup to the first instance of the part works fine, but then I can't make an array out of it...
It would be so great if this thing was sorted.
herbk
Post by herbk »
Hi Tomi,
the Holding Tags dressup works if you work at this order:
create your contour path
create the array of this path
right click the countour path and select the HT dressup (finish this)
select the array, continue with Menue ->Path ->Path Dressup and Select the HT dressup
At the array you have to set the "holding points" manuell, but that's easy. Click Add at the Dressup UI and click at the green path line where you wants to have a tag.
If you want to have a Ramp entry and Holding Tags, make first the Ramp Entry dressup (same procedure). Adding a HT dressup to a RE dressup works, but not vice versa.
Gruß Herbert
Giulio Buccini
Post by Giulio Buccini »
I second this feature request.
The proposed workaround make a mess in my case...
xf3qc
Post by xf3qc »
same here.
Array is not usable in 0.19 for me.
in 0.18 path dress up was not necessary on path operation or arrays as leadin/out was automatic.
Anyway to go back to that functionality?
GeneFC
Post by GeneFC »
xf3qc wrote: Sat Jul 11, 2020 2:31 pm in 0.18 path dress up was not necessary on path operation or arrays as leadin/out was automatic.
I do not think that automatic leadin/out has ever been true. You need to select it.
Gene
xf3qc
Post by xf3qc »
GeneFC wrote: Sat Jul 11, 2020 2:59 pm
Gene
Thanks for a reply GeneFC
no automatic leadin/out been mentioned to me several times. This is so odd.
Including screenshots of 0.18 vs 0.19
What am I missing.
GeneFC
Post by GeneFC »
I am not sure exactly what you are showing, but that is not what I call leadin/leadout. Typical use of leadin/leadout is to ease up to or away from a profile edge instead of an abrupt motion. Makes a smoother cut.
What you seem to be showing (I am not sure) relates to the retract to safe height and clearance height between the array elements. A lot of changes have been made in that topic. I don't like the changes, so I override them and have not paid much attention.
Gene
