ISO tool definitions:
ALP Clearance angle axial
ANN Clearance angle minor
APMX Depth of cut maximum
B Shank width
BAWS Body angle workpiece side
BBD Balanced by design
BBR Balanced by rotational test
BD Body diameter
BHTA Body half taper angle
BS Wiper edge length
BSG Basic standard group
CDX Cutting depth maximum
CHW Corner chamfer width
CICT Cutting item count
CND Coolant entry diameter
CNSC Coolant entry style code
COATING Coating
CNT Coolant entry thread size
CP Coolant pressure
CRKS Connection retention knob thread size
CTPT Operation type
CUTDIA Work piece parting diameter maximum
CW Cutting width
CWTOLL Cutting width lower tolerance
CWTOLU Cutting width upper tolerance
CXSC Coolant exit style code
CZC Connection size code
CZC MS Connection size code machine side
CZC WS Connection size code workpiece side
DAH Diameter access hole
DAXIN Axial groove inside diameter minimum
DAXX Axial groove outside diameter maximum
DBC Diameter bolt circle
DC Cutting diameter
DCB Connection bore diameter
DCBN Connection bore diameter minimum
DCBX Connection bore diameter maximum
DCF Cutting diameter face contact
DCON Connection diameter
DCSFMS Contact surface diameter machine side
DCSFWS Contact surface diameter workpiece side
DCX Cutting diameter maximum
DIX Tool changer interference diameter maximum
DMIN Minimum bore diameter
DMM Shank diameter
DN Neck diameter
DSGN Design
D1 Fixing hole diameter
FHA Flute helix angle
FLGT Flange thickness
FTDZ For thread diameter size
H Shank height
HF Functional height
HRY Lowest point from reference plain
HTB Body height
HTH Height
IC Inscribed circle diameter
INSL Insert length
IZC Insert size code
KAPR Tool cutting edge angle
KCH Corner chamfer
L Cutting edge length
LB Body length
LCF Length chip flute
LE Cutting edge effective length
LF Functional length
LGR Regrind length
LH Head length
LPR Protruding length
LS Shank length
LSC Clamping length
LSCN Clamping length minimum
LSCX Clamping length maximum
LSD Dead shank length
LU Usable length (max. recommended)
MHD Mounting hole distance
MIID Master insert identification
MMCC Code for preset torque
NOF Flute count
OAH Overall height
OAL Overall length
OAW Overall width
OHN Overhang minimum
OHX Overhang maximum
PHD Premachined hole diameter
PHDX Maximum premachined hole diameter
PL Point length
PRFRAD Profile radius
PRSPC Profile specification
PSIR Tool lead angle
PSIRL Cutting edge angle major left hand
PSIRR Cutting edge angle major right hand
RADH Radial body height
RADW Radial body width
RE Corner radius
RETOLL Corner radius lower tolerance
RETOLU Corner radius upper tolerance
RPMX Rotational speed maximum
S Insert thickness
SDL Step diameter length
SIG Point angle
SSC Insert seat size code
SUBSTRATE Substrate
TCDC Tolerance class cutting diameter
TCDMM Shank diameter tolerance
TCHA Achievable hole tolerance
TCT Tolerance class tool
TCTR Thread tolerance class
TD Thread diameter
TDZ Thread diameter size
TFLA Tap floating length ahead
TFLB Tap floating length behind
THCHT Threading chamfer type
THFT Form type
THLGTH Thread length
THUB Hub thickness
TP Thread pitch
TPI Threads per inch
TPIN Threads per inch minimum
TPIX Threads per inch maximum
TPN Thread pitch minimum
TPX Maximum thread pitch
TQ Torque
TSYC Tool style code
ULDR Usable length diameter ratio
WB Body width
WF Functional width
WSC Clamping width
WT Weight of item
W1 Insert width
ZEFF Face effective cutting edge count
ZEFP Peripheral effective cutting edge count (ZEFP)
ZWX Maximum number of Wiper inserts
People complain about the few we have to fill in now!!
