Thank you my Freecad friends for your answer.
What about if I limit the shape with a cut with offset 3mm from the curve?
Is it then possible to mill just the face and the curve?
I get errors on loading:freecad-heini-1 wrote: ↑Mon Jan 15, 2018 5:45 pmIs it then possible to mill just the face and the curve?
<unknown exception traceback><type 'exceptions.ImportError'>: No module named CompoundFilter2
Yes Chris.chrisb wrote: ↑Mon Jan 15, 2018 6:30 pmI get errors on loading:freecad-heini-1 wrote: ↑Mon Jan 15, 2018 5:45 pmIs it then possible to mill just the face and the curve?probably due to missing workbenches. Can you please upload it as simple copy.Code: Select all
- Select flat top around the oval
It's currently not working properly. The tool moves but takes no material off.freecad-heini-1 wrote: ↑Mon Jan 15, 2018 10:35 pmWhow, great, thank you so much.
What about the toolpath simulation like to see here?
I see. The outside is higher, which means that it is impossible to mill it.
