I took a pass at the Path FromShape wiki, but realized there's something fundamental I haven't figured out about a couple of things in Path WB that needs to be documented.
For some objects, like FromShape, FromArea, etc... the result gets added outside the Job. FromShape generates G-Code tool-paths--other than using the InspectGCode tool to copy the GCode, and then pasting it into a CustomGCode, within a Job, is there an intended use for these?
