Changes in circular profile path?
schnebeck
Postby schnebeck » Sun Jan 28, 2018 10:26 pm
Hiho,
I just tried last daily-build:
OS: Ubuntu 14.04.5 LTS
Version: 0.17.13165 (Git)
Build type: None
Hash: acded1c954b54e5497a661b4b0c7524d345ce2fc
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
I have some problems to create a simple circular profile path. After that I want to use a helix ramp dressup.
But every (edge|face) profile functions generates a strange wrong path that has wrong diameter and does not respect CW/CCW direction.
I only know that kind of path used by 3D-printers 8-)
Here is the outer path of the highlighted profile
and here is the simulation, where you see the wrong diameter.
I remember there was at least a thread in the past about wrong diameter but I could not find it :?
Bye
Thorsten
profile-bug.fcstd
(179.42 KiB) Downloaded 14 times
mlampert
Re: Changes in circular profile path?
Postby mlampert » Mon Jan 29, 2018 1:41 am
confirmed, I have an older version from 5 days ago which produces correct paths, but the latest doesn't anymore. The only change in this area happened in PathArea.
realthunder wrote:ping
wanna have a look?
mlampert
Postby mlampert » Mon Jan 29, 2018 1:49 am
Forgot to mention in the latest version there are also these 2 error messages:
<Path.Area> Area.cpp(1236): project failed
<Path.Area> Area.cpp(1378): empty projection
realthunder
Postby realthunder » Mon Jan 29, 2018 3:56 am
Submitted a fix for this. Please check.
I didn't see these error messages. Does it occur with the attached file? If not, please attach a files showing the problem.
