help needed
Re: help needed
I get the message in Report view: "File was not written with this version of the topology". Did you reuse some old file and trie to pimp it? If so please re-create it from scratch.
Re: help needed
I get that message very often, even with files I have just created and reopened. It indicates an error of some sort, but it never seems to cause any problems at all.
Gene
Re: help needed
Hi efix,
to create a 3D pocket from a part wich is not a pocket, the part has to have a flat area at the bottom.
- connector_01.FCStd
- (260.77 KiB) Downloaded 26 times
Gruß Herbert
Re: help needed
With a 3 axis mill, there will be allways some steps. Just make the stepdown size smaler and the steps getting smaler to...
With a big area on the ground (as i made) it's a lott of milling time then, but the "groundplate" need's not to be so big.
For a better 3D surface at all you need to run a 3D Pocket operation first and a 3D surfacing operation secound. But the D surfacimg dosn't work without installing OCL atm, which not is so easy at some Operating systems.
Gruß Herbert
Re: help needed
I create Facing Operation (no 3d surface on my version) and then I choose all rounded surfaces and generate mesh, but only what I've got after simulation was flat surface on top not over all rounded edges. Why? Because of that OLC?
Edit: What is OLC and where to get this?
Re: help needed
Check the wiki, which has a lot of good info about configuring, and using Path-WorkBench:efyx wrote: ↑Fri Mar 23, 2018 7:28 amI create Facing Operation (no 3d surface on my version) and then I choose all rounded surfaces and generate mesh, but only what I've got after simulation was flat surface on top not over all rounded edges. Why? Because of that OLC?
https://www.freecadweb.org/wiki/Path_Workbench
https://www.freecadweb.org/wiki/Path_3DSurface
Or the many forum posts regarding Open Cam Library (OCL)--for example...
https://forum.freecadweb.org/viewtopic.php?t=18155
https://forum.freecadweb.org/viewtopic.php?t=16956
https://forum.freecadweb.org/viewtopic.php?t=27535
https://forum.freecadweb.org/viewtopic.php?t=17548
https://forum.freecadweb.org/viewtopic. ... 5&start=20
Etc..........
In the wiki, make sure you look into enabling experimental features.
If you are using Linux, it will be more straightforward. If Windows, I had trouble compiling OCL, but then noticed in one of the threads that a compiled version is linked.
Re: help needed
Thanks JoshM. I am on Windows. I try to follow https://github.com/aewallin/opencamlib/ ... er/Windows right now I am downloading visual studio to compile boost. I'll let know when I'll turn it on and it would start working.
Re: help needed
Fastest way is just to use the pre-compiled version
https://github.com/sgrogan/opencamlib/r ... ag/8612634
"fight the good fight"
