Tool-Library: Cutting Edge Angle
schnebeck
Postby schnebeck » Wed Jan 31, 2018 6:40 pm
Hiho,
I read in the wiki that you must enter a Cutting Edge Angle of 180° for a tool otherwise the simulation can crash.
But I can only enter a 2 digit number <= 90° :?:
I can enter "180°" in the Toolcontroller-Tool-Editor, but when I press enter its changed to 90°
So, any new info about this?
Bye
Thorsten
OS: Ubuntu 14.04.5 LTS
Version: 0.17.13190 (Git)
Build type: None
Hash: 70399e6c9c6506a6eb7849c6835557b40adb1db0
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
Re: Tool-Library: Cutting Edge Angle
Postby chrisb » Wed Jan 31, 2018 7:09 pm
It's one of the recent changes that mlampert or sliptonic made. They mentioned it here in the forum.
sliptonic
Postby sliptonic » Wed Jan 31, 2018 8:04 pm
What does a tool with a 180 degree cutting angle look like?
Postby chrisb » Wed Jan 31, 2018 9:38 pm
If we look at the cutting angle of a drill it has - at least overhere - a most common cutting angle of 118°. This means the cutting angle has its center in the middle of the tool tip and measures to both sides.
An angle of 180° would be an end mill.
herbk
Postby herbk » Thu Feb 01, 2018 6:50 am
Hi Chris,
but it's, like you say, a drill... ;)
The angle you are talking about is called "spitzenwinkel" in german, translated to nose- or point- angle by google. :)
Gruß Herbert
Postby chrisb » Thu Feb 01, 2018 8:46 am
You are right. I forgot in my last post: All we need is an appropriate image. We have discussed this here before, I will look for the topic.
Postby chrisb » Thu Feb 01, 2018 9:05 am
Here is one of the topics including a FreeCAD TechDraw image: https://forum.freecadweb.org/viewtopic. ... 17#p186875
Postby chrisb » Thu Feb 01, 2018 9:14 am
sliptonic
Postby sliptonic » Thu Feb 01, 2018 4:25 pm
Clearly this issue keeps coming up again and again. We need to stop mucking about with shovels and rakes, get into a bulldozer and dig a solution out once and for all. This is probably going to be a significant piece of development work which means 0.18 at the earliest.
I've created a new feature issue in mantis for this: https://freecadweb.org/tracker/view.php?id=3336 I set priority high but left it unassigned for now. If someone doesn't want to own it outright from the beginning, we might see if all or part of it is appropriate for a GSoC project.
Please get used to this issue number and tag any other forum threads with it. Add comments, design ideas, and links to external references.
'Old number 3336' might be with us for a while.
Postby chrisb » Thu Feb 01, 2018 6:53 pm
I bookmarked it in my to-be-tracked folder.
