Drilling feed speed?
kbrown
Postby kbrown » Thu Feb 08, 2018 1:14 am
First post in the forums so apologies if this has already been discussed. I've just recently started learning the Path module in FreeCAD. I decided to install the freecad-daily version instead of the old 0.15 that came from the default linuxmint repos. Here's the version info I'm on right now:
Version: 0.17.13217 (Git)
Hash: 89275766de909a5c1f36e962806dc7b4a0b0f47b
My issue is that I cannot seem to set the feed rate for my drilling operations. I've set the operation's tool controller to a tool which I've set to have 100mm/s horizontal and 10mm/s vertical feed rates. However when I post process (linuxcnc) the job it comes up with g-code lines like this:
G83 X50.000 Y21.077 Z-0.500 F600.000 Q0.100 R1.000
Where does it get the F600 from? I haven't got such feed rates anywhere in my project afaik.
roivai
Re: Drilling feed speed?
Postby roivai » Thu Feb 08, 2018 8:42 am
Hi and welcome!
LinuxCNC expects feed rates in mm/min (or inch/min if set for inches). So that 10mm/s is translated to 10*60=600mm/min.
roivai
kbrown
Postby kbrown » Thu Feb 08, 2018 4:36 pm
Ah of course. Coming from HeeksCNC I'm used to deal with mm/min rather than mm/s. Makes sense now. Thanks!
