I've limited my maximums from what my machine can "theoretically" do to what it can "reliably" do...sliptonic wrote: ↑Tue Feb 13, 2018 4:44 pmOut of curiosity, why would you ever run with a rapid rate slower than the machine is able to go? I suppose during a first test run, you might want to minimize a chance of a crash. But with known gcode, I can't think of a case where the user would choose to go slower. That's not true of Feed. I can think of several cases where the operator would choose to go slower or faster, even with proven gcode.
[MERGED] Approximate/rough guess of milling time
Re: Approximate/rough guess of milling time
That is exactly the reason I slow down. Probably half of the things I do are not repeated, so I operate in "tryout mode" a lot of the time. (with my hand close to the E-Stop.)sliptonic wrote: ↑Tue Feb 13, 2018 4:44 pm Out of curiosity, why would you ever run with a rapid rate slower than the machine is able to go? I suppose during a first test run, you might want to minimize a chance of a crash. But with known gcode, I can't think of a case where the user would choose to go slower.
I ran a lot of stress tests before finalizing my basic rapids and accelerations. I chose numbers that never gave dropped steps or other quirks. I greatly prefer a few percent more time compared to a few percent more scrap.
I work a lot in stainless steel, so feed rates are quite low, and rapids are not a very big portion of the total time. I can be pretty conservative without significant penalty.
Of course a job shop might take a different view of the value of time
Gene
- Pauvres_honteux
Anyone of ye merry cnc-owners being merciful and check "roivai's"script versus reality? Mabye it works on specific areas/volumes?
roivai wrote: ↑Mon Feb 12, 2018 8:25 pm
Here's a quick scratch I made. It seems to output a number, I really did not have time to analyze/compare if it makes any sense. Does not support drilling cycles.
import FreeCAD, FreeCADGui, Part, Path from PathScripts.PathGeom import PathGeom #select the Job object sel = FreeCADGui.Selection.getSelection() # the expected rapid feed is taken from the first tool controller in the Job tc = sel[0].ToolController[0] horizrapid = tc.HorizRapid curX = 0 curY = 0 curZ = 0 curFeed = 0 time = 0 for cmd in sel[0].Path.Commands: if cmd.Name in ['G0', 'G1', 'G2', 'G3']: p=Path.Path() p.addCommands([cmd]) w, r = PathGeom.wireForPath(p, startPoint=FreeCAD.Vector(curX,curY,curZ)) length = w.Length if 'X' in cmd.Parameters: curX = cmd.Parameters['X'] if 'Y' in cmd.Parameters: curY = cmd.Parameters['Y'] if 'Z' in cmd.Parameters: curZ = cmd.Parameters['Z'] if cmd.Name == 'G0': curspeed = horizrapid.Value else: if 'F' in cmd.Parameters: curFeed=cmd.Parameters['F'] curspeed = curFeed time = time + length/curspeed print str(time) + " sec"
One reason you might slow down in production runs, is that the machine has some issue, but not too bad so you can continue with a lower feedrate... On our CNC machine we had the problem that the lead screws would start to vibrate on higher speeds, as somehow they would resonate with the motion. Therefore we reduced the speed during the program run.
What about the following option: Give the total estimate but split it also down into the separate parts, like G0, G1, ..., G81. For fancyness you could also calculate the average feed rate.
I tried the script btw, but I get this error message:
edit: okay I got it to run, the problematic commands are those:
('error', Command G0 [ F:40 Z:15 ])
('error', Command G0 [ F:40 Z:13 ])
from a helix drill operation. I tested it on a blank file and it worked there. Maybe the file is too old?
Anyways, the script tells me 163s - LinuxCNC says 2.2min (132s). I also runned it in the simulator and got to 3min 23s... Not sure where this difference comes from, but the script was a little bit closer I plan to produce this thing in the next weeks or so, so maybe I remember and stop the time.
File "/home/reox/.FreeCAD/Macro/Milltime.FCMacro", line 20, in <module>
File "/usr/lib/freecad-daily/Mod/Path/PathScripts/PathGeom.py", line 342, in wireForPath
return (Part.Wire(edges), rapid)
<class 'Part.OCCError'>: BRep_API: command not done
OS: Debian GNU/Linux testing (buster)
Version: 0.17.13247 (Git)
Build type: None
Hash: 5022c8df5cef0690f2c8acff4bcebd82655a5f04
Python version: 2.7.14
OCC version: 7.1.0
Locale: German/Austria (de_AT)
- Pauvres_honteux
Easter is coming and... one would then of course have a virtual Easter egg mold!
I could not make the script provided by roivai to work. Anyone else like to try?
Did you get a "division by zero" error? The rapid feedrate was set to 0 in your file. I set it to 5mm/sec and got:Pauvres_honteux wrote: ↑Sat Feb 17, 2018 1:39 pm Easter is coming and... one would then of course have a virtual Easter egg mold!
Easter_egg_Milling_test.fcstd
2852.46260517 sec
- Pauvres_honteux
Did you try clicking this one? By default those feed rates are bound to the setup sheet values, so another option is to go to SetupSheet and set it there, there you can simply edit it without clicking the expression icon.Pauvres_honteux wrote: ↑Sat Feb 17, 2018 8:29 pmHow did you change that? Here it´s blocked! In user interface that is.
I think you should edit that in the SetupSheet, especially when using LinuxCNC as it does not recognize those values...
- Pauvres_honteux
