it seems that PathPost.py has a problem postprocessing. It smashes
trying to open the file save dialog. If I modify the script to avoid opening the dialog
then everything else seems to work and I get sane outputs.
I'd fix it if I understood where QtGui.qApp should be initialized, but I have no idea.
Why is it uninitialized ?
Cheers
fbx
Path workbench activated
PathPost.DEBUG: about to postprocess job: Job
PathPost.DEBUG: obj: MillFace
PathPost.DEBUG: obj: Pocket_Shape
PathPost.DEBUG: obj: Profile_Edges
PathPost.DEBUG: obj: Pocket_Shape001
PathPost.DEBUG: obj: TagDressup
PathPost.DEBUG: obj: Profile_Faces002
Running the Python command 'Path_Post' failed:
File "/Applications/FreeCAD.app/Contents/Mod/Path/PathScripts/PathPost.py", line 259, in Activated
(fail, rc) = self.exportObjectsWith(postlist, job)
File "/Applications/FreeCAD.app/Contents/Mod/Path/PathScripts/PathPost.py", line 187, in exportObjectsWith
filename = self.resolveFileName(job)
File "/Applications/FreeCAD.app/Contents/Mod/Path/PathScripts/PathPost.py", line 140, in resolveFileName
foo = QtGui.QFileDialog.getSaveFileName(QtGui.qApp.activeWindow(), "Output File", filename)
'NoneType' object has no attribute 'activeWindow'
My version data:
OS: Mac OS X
Version: 0.17.13511 (Git)
Branch: (HEAD detached at 5773170)
Hash: 5773170777f424c932f2088ef92d5f664b7d3c23
Python version: 2.7.14
Qt version: 5.10.1
OCC version: 7.2.0
Locale: English/Switzerland (en_CH)
v0.17-0.18 - Error in postprocessor
Re: v0.17-0.18 - Error in postprocessor
I ran into this on 0.17; both the April release and the Latest August release.
I see that the pull request was for :master. Any chance this fix can be applied to 0.17 branch too?
OS: Mac OS X
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Qt version: 5.10.1
OCC version: 7.2.0
Is there a reason why you don't use 0.18? The release is before the doors and I guess noone will backport things to 0.17.
I didn't know 0.18 was that close. Is there a release candidate? That's a lot faster than 0.17 took.
Anyway, I'd still rather use a stable version. There are understandably changes to objects and files that break from build-to-build on the development version. I can't risk having my projects broken because of that.
Knowing the fix, I was able to use sed to replace all "qApp" with "QApplication" and fix my problem.
You can give it a try and install both versions in parallel. 0.18 seems to be more stable than 0.17, many things have been fixed and smoothed.berka wrote: ↑Mon Oct 29, 2018 12:45 am I didn't know 0.18 was that close. Is there a release candidate? That's a lot faster than 0.17 took.
