path 3d pocket is doing some wrong
when i want to mill that part at pic 1 by using "path 3d pocket" sometimes it works fine, see pic 3
a 2nd problem is that the toolpath always end at the selected face, but all 4 faces are one thing, so when i mill i allways have a wall between thes faces. that's not nice, but the first problem is really a problem !
thanks for help
, but at pic 2 and 3 you can see that the cutter goes in one case ok and in one case goes parallel down what is not ok,, at the other half-circle it goes ok and sometime if i only select one face to base geometery it goes parallel down and when i select a second face to base geometry it fails. i made yesterday one "path 3d pocket" all was ok, today always one half-circle allways goes parallel in z-direction. i made no modify at my part ! what is the problem ?a 2nd problem is that the toolpath always end at the selected face, but all 4 faces are one thing, so when i mill i allways have a wall between thes faces. that's not nice, but the first problem is really a problem !
thanks for help
- fc_gerade_p3.png (218.32 KiB) Viewed 1216 times
- fc_gerade_p1.png (252.7 KiB) Viewed 1216 times
Re: path 3d pocket is doing some wrong
i can confirm that there go's something wrong:
OS: "openSUSE Leap 42.3"
Version: 0.18.13516 (Git) AppImage
Build type: None
Hash: 7101d9a89d49ed718d42611a81f1097b723e5ad2
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.2.0
Btw: Why the path is made in 4 parts? - it is one pocket only, made with one cut.
It's made with:OS: "openSUSE Leap 42.3"
Build type: None
Qt version: 4.8.6
OCC version: 7.2.0
- oval.fcstd
- (54.39 KiB) Downloaded 24 times
Gruß Herbert
As for the second issue: There are four faces so currently there are four separate paths. As for the first problem: it might be some internal coplanar problem, could you try to turn your object by a few or even by 90° and tell what happens?
hello,
today i tryed again...
first: it is not a oval ! there are 2 half circle and 2 straight
second: i rotated -90 degree because so my machine is build and when i select the operation zigzag it works (terrible) but when i select spiral fc crashes
third: i used a older construction-file and in the original wrong position it works using spiral but -90 degree in Z it crashes
another problem is the accurancy, if i select a tool 6mm ball it generates in my grove at the last layer 2 paths and no last in the middle, is there a parameter i dont know ?
today i learned a lot, thanks the crashes and this forum, thanks to all !
OS: Ubuntu 16.04.4 LTS
Version: 0.18.13588 (Git)
Build type: None
Hash: 1e2b9758cc7f6872da018ee71983a82499866508
Python version: 2.7.12
OCC version: 7.2.0
Build type: None
OCC version: 7.2.0
I can contribute only to the last point: currently the Path workbench does not respect different tool shapes. The toolpath is alway calculated for an end mill.
thanks for info,
what do you mean with "end mill" only flat one ? no ball ?
Only flat; that's what I thought to be an end mill, but english is not my native language, so misunderstandigs are likely.
hi,
now i tryed to another way to get my groove, i cutted it flat and use path-pocket but insert a 8mm ball cutter to get the roundings. but now fc makes 6 interrupts in my path. i tryed with lower tolerance and at last i insert a 7,5 mm cutter but the interrupts are the same.
it looks realy strange at the passage from curve to straight, at 2 positions it works, at other 2 not.
has anyone a idea ?
thanks
has anyone a idea ?
thanks
- sliptonic
It's not ideal, but you could try selecting the outer edges of the oval loop and then do an edge profile. Edge profiling will work on the edges as a loop rather than the individual faces.
Looks like your tool has the same width as the slot - what you see are probably rounding issues where the slot ends up being smaller than the tool.
