Path workbench not working
What could be the solution for this error?
Running the Python command 'Path_Job' failed:
File "C:\Program Files (x86)\FreeCAD 0.17\Mod\Path\PathScripts\PathJobCmd.py", line 117, in Activated
dialog = DlgJobCreate()
File "C:\Program Files (x86)\FreeCAD 0.17\Mod\Path\PathScripts\PathJobCmd.py", line 59, in __init__
for path in PathPreferences.searchPaths():
File "C:\Program Files (x86)\FreeCAD 0.17\Mod\Path\PathScripts\PathPreferences.py", line 123, in searchPaths
paths.append(cls.macroFilePath())
File "C:\Program Files (x86)\FreeCAD 0.17\Mod\Path\PathScripts\PathPreferences.py", line 115, in macroFilePath
return grp.GetString("MacroPath", FreeCAD.getUserMacroDir())
'ascii' codec can't encode character u'\xe1' in position 10: ordinal not in range(128)
Re: Path workbench not working
Would you mind telling us a bit more after reading the IMPORTANT message linked above?
- FreeCAD info
- what did you do exactly
- active workbench
Hi.
- I am using Version 0.17.
- All preferences are default
- In Path preferences default path to look for templates, post processors, tool tables and other external files is empty which refers to default general macro path and this macro folder is empty. Probably this must be defined to correct location (need some help here).
- Active worknench: Path
- In path workbench only "New Job" fuction is available and all others are grey.
- Trying to create a new Job and the following message appeares:
"Running the Python command 'Path_Job' failed:
'ascii' codec can't encode character u'\xe1' in position 10: ordinal not in range(128)"
Some screenshots.
- 2018-05-22 10_18_26-FreeCAD.png (99.53 KiB) Viewed 2500 times
- 2018-05-22 10_18_11-FreeCAD.png (92.78 KiB) Viewed 2500 times
- 2018-05-22 10_17_58-FreeCAD.png (76.29 KiB) Viewed 2500 times
- 2018-05-22 10_17_34-FreeCAD.png (55.7 KiB) Viewed 2500 times
Word size of FreeCAD: 32-bit
Version: 0.17.13522 (Git)
Branch: releases/FreeCAD-0-17
Hash: 3bb5ff4e70c0c526f2d9dd69b1004155b2f527f2
Python version: 2.7.14
OCC version: 7.2.0
Locale: Hungarian/Hungary (hu_HU)
OCC version: 7.2.0
The error message looks as if you have some fancy character - probably hungarian - in your macro path. Try with a path which only uses ascii charcters.
Problem solved. Thank you for your kind support.
Some path actions functioning well like: creatring a job, MillFace, Contour, but Pocket_Shape gives me an error message as shown on the screenshot. What could be the problem?
- 2018-05-23 10_10_25-FreeCAD.png (139.41 KiB) Viewed 2450 times
Did you follow the Path Walkthrough for the Impatient? It uses pocket from shape.
Besides that: if you want more, give us more.
I followed the Path Walkthrough for the Impatient and it is still not working. Sorry for my poor knowlegde on FreeCAD basics. Let me ask you to kindly provide me some general requests and questions to answer regarding troubleshooting so you could have a better understanding of my problem.
