Difficulty with full depth pockets...
Re: Difficulty with full depth pockets...
Postby chrisb » Thu May 17, 2018 10:02 pm
And again nothing special on my Ubuntu system. Both versions mentioned belowbehave the same: Load the first file you uploaded, mark for recompute, recompute and there you are:
There is a very faint chance that it's the occ version, but I really don't think so, because it is nothing special what you do. Have you tried the Appimage?
OS: Ubuntu 16.04.4 LTS
Version: 0.18.13712 (Git)
Build type: None
Hash: 57b7f3389a846454d01c2abea509b8394099735c
Python version: 2.7.12
OCC version: 7.2.0
Version: 0.18.13671 (Git)
Build type: None
Hash: c36026358222da48a1a8ab3eec87a4a4a5166b7e
OCC version: 7.2.0
glockpod
Postby glockpod » Thu May 17, 2018 11:20 pm
Build type: None
OCC version: 7.2.0
Build type: None
OCC version: 7.2.0
That's great, only it doesn't work that way on my system. Recompute, and I get to exactly what I posted.
I prefer to use the github images.
It's a bit of a problem, though, OCC7.2.0 requires tcl8.6.3 or better, and Debian is stuck on 8.6.0-2
I'll work something out.
-Chuck
-Chuck
bill
Postby bill » Fri May 18, 2018 3:43 am
Are you using style-sheets?
Beware there is some type of situation/state/bug (config file CRUD) that was CRIPPLING my 17-522 installation on ubuntu.
May be a style-sheet problem!
It was impacting the opening and manipulation of files I presume.
Sketches and Pads would never appear in the tree. Same file opened in 18 worked fine.
The only constant was a malformed UI; for instance:
Note the deformed separators as blobs instead of dots and lack of down arrow in the workbench selection tool.
When I looked at my preferences style-sheet, my installation said NO STYLE SHEET.
Only problem is that there was one being displayed.
When I set the style sheet to the one displayed, it accepted and all file information is visible and accessible.
Problem vanished into thin air now that I am bald!
DudleyCondon3
Postby DudleyCondon3 » Fri May 18, 2018 6:42 pm
OHHH, for my case, it's the style sheet problem! Thank you so much! You saved the day.
Postby chrisb » Fri May 18, 2018 10:28 pm
Where is the information about the used style sheet stored? It is not in the config files, deleting them had no effect.
bill
Postby bill » Sat May 19, 2018 1:30 pm
in user.cfg:
Postby chrisb » Mon May 21, 2018 6:45 pm
It seems that I was wrong. I tried again and deleted my config file which reset my settings including the style sheet.
Thanks bill.
glockpod
Postby glockpod » Sun May 27, 2018 1:47 pm
Build type: None
OCC version: 7.2.0
Build type: None
OCC version: 7.2.0
-Chuck
Ok, I loaded a new computer with a fresh install of Debian Stretch, and built a fresh copy of OCC7.2, and FreeCad from Git. And the problem is resolved by recalculation, as you all have stated.
However, that doesn't explain what caused the problem in the first place.
But, darn the ecology, full steam ahead, running two server class machines in my office, instead of one, must be better?
-Chuck
gpothier
Postby gpothier » Tue Nov 06, 2018 11:55 am
Hi, I'm also experiencing this on FC daily and 0.17 (see screenshots). If I check "use outline", the pocket goes to the desired depth. If I uncheck it, it stops before reaching the desired depth (but it cuts trough raised features, so it does not solve the problem here). Was a bug report filed, or should I file one?
OS: Ubuntu 18.10
Version: 0.18.15115 (Git)
Hash: 684b4ab03a27231e0cc603ca815bf9ea367fd0b9
Python version: 2.7.15+
Screenshot from 2018-11-06 08-32-07.png (429.86 KiB) Viewed 250 times
Screenshot from 2018-11-06 08-32-24.png (553.98 KiB) Viewed 250 times
gpothier
Postby gpothier » Fri Nov 09, 2018 2:25 pm
Well I went ahead and filed https://www.freecadweb.org/tracker/view.php?id=3675
Regards,
g
