Ramp entry (helix) too steep
Re: Ramp entry (helix) too steep
Postby chrisb » Wed May 23, 2018 4:29 am
roivai wrote:
Tue May 22, 2018 7:35 pm
Any comments before I make a PR?
Thank you!
GeneFC
Postby GeneFC » Wed May 23, 2018 2:52 pm
The term "IgnoreAbove" probably carries little meaning unless the user already understands the shorthand notation.
If I understand the logic, then "BeginAtStartDepth" might be a bit clearer.
Either way, a nice update.
Gene
roivai
Postby roivai » Wed May 23, 2018 5:55 pm
Good suggestion. Actually, I went even further and called them UseStartDepth and DressupStartDepth. PR is here:
https://github.com/FreeCAD/FreeCAD/pull/1467
herbk
Postby herbk » Mon Oct 22, 2018 8:31 pm
Hi roivai,
ping
there is a new problem if using the ramp entry dressup: it only removes the ramp, not the whole material.
Th screenshot is taken at a Millface OP, but the behavior is the same at Pocket OP and Pocket 3D.
Gruß Herbert
roivai
Postby roivai » Wed Oct 24, 2018 1:03 pm
I suppose you are using helix method? I think I have seen that at some point, then was not able to reproduce it and forgot the whole thing.. Basically what happens (I think) is that is does consider that round as the last round for some reason, maybe rounding error or something, so it does not add the final "flat" cutting loop. Can you send me that file?
herbk
Postby herbk » Wed Oct 24, 2018 8:17 pm
Hi roivai,
yes it's the helix ramp, - and file is attached.
Halter_6_cells.fcstd
(40.98 KiB) Downloaded 11 times
Gruß Herbert
roivai
Postby roivai » Thu Oct 25, 2018 5:48 am
Hi roivai,
Thanks for the file. The bug was even more obvious than I originally expected. When the dressup was searching for minimum Z on the path, it included the first edge from (0,0,0) to actual starting position. So it always found 0 as the minimum Z if the actual path did not go below zero. It seems that I've never tried this with a model where the bottom of the cut is above zero. Not very good testing coverage.
Pull request is at https://github.com/FreeCAD/FreeCAD/pull/1746
