Hi, I just wanted to ask a simple question,
when I read the Gcode for any of my operations, I do not have the command showing to turn the spindle on (M03) or the spindle speed setting S10000 (or whatever).
It's easy enough to add them, but I was curious as to why they are not there? (bug or feature?)
I also noticed on a job I cut earlier today, the spindle speed rpm kept changing from 20k to 25k (25K is what I had set), it ran at 20k while horizontal cutting but 25K while vertical plunging??
The job is very simple, only 2 operations, 1 circular pocket and the contour cut, both cut with a 5mm HSS end tool (the default tool)
Any suggestions or have I missed something?
regards,
Eric
OS: Debian GNU/Linux 9.4 (stretch)
Version: 0.18.13721 (Git)
Build type: None
Hash: afdd30b137cdfd096c61c4aee270025115d0f8d6
Python version: 2.7.14
OCC version: 7.2.0
Missing Gcode to turn spindle on
Re: Missing Gcode to turn spindle on
Turning on the spindle and it's speed is done by the ToolController which gets inserted by the driver for the post processor. Individual ops don't have pre-ambles, setups or post-ambles.
This must be something your machine controller does. I checked the resulting g-code and it does not include a directive for 20k rpm.I also noticed on a job I cut earlier today, the spindle speed rpm kept changing from 20k to 25k (25K is what I had set), it ran at 20k while horizontal cutting but 25K while vertical plunging??
The only odd thing I noticed is that there are`M6` and `M3` commands for each op although it's the same TC.
EDIT: created issue #3490 for the TC issue.
thanks for the reply
You stated
Eric
You stated
As I said, I do not see any M3, M6 or Sxxx commands in the post processed code, I do have the spindle speed set in the TC, how come you see them?The only odd thing I noticed is that there are`M6` and `M3` commands for each op although it's the same TC.
Eric
My Bad,
forget all above (except multiple M6 T1 code), I have been exporting other files to STL for 3D printing and I exported the gcode instead of using the post process icon, DUH!
thanks for the support
Eric
Eric
