two glitches in simulator
schnebeck
Postby schnebeck » Tue May 22, 2018 8:27 am
OS: Ubuntu 14.04.5 LTS
Version: 0.18.13728 (Git)
Build type: None
Hash: 4f5e304d64d79eb64d3b96f41cdc5293522958ef
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.2.0
When there is a path op without tool-controller like 'fixture' simulation generates an error - although the operation is disabled in simulation
And there is a typo:
freecad-daily/Mod/Path/PathScripts/PathSimulatorGui.py", line 490, in InvalidOperation
    return false
NameError: global name 'false' is not defined
false -> False
HTH
Thorsten
Re: two glitches in simulator
Postby chrisb » Tue May 22, 2018 11:32 am
The tool controller issue has been discussed here before. The search might give further information.
glockpod
Postby glockpod » Sun May 27, 2018 1:34 pm
The problem still exists in the code base as of May 27.
The fix is simple, change all occurrences of the word "false" to "False" in the source for the file /usr/local/Mod/Path/PathScripts/PathSimulatorGui.py.
The effect of the typo is to prevent the start the PathSimulator simulation, and to burp up an error on stderr complaining about "false" not being defined.
It takes longer to describe the problem than it does to fix it.
-Chuck
roivai
Postby roivai » Sun May 27, 2018 7:05 pm
