Linux APP Image - How to add custom postprocessor
borrisl
Post by borrisl »
Professionally I use Linux for everything. FreeCAD makes me smile with its support for the OS.
Therefore I'm using the monolithic AppImage for execution of the application. I would like to write my own postprocessor. Where do I place the postprocessor so that the application can find it?
Re: Linux APP Image - How to add custom postprocessor
borrisl wrote: Sat Jun 02, 2018 1:19 am Where do I place the postprocessor so that the application can find it?
Hi borissl, welcome to FreeCAD.
The post processor should follow the naming convention <nameOfControl>_post.py. The _post.py is required! You place it in your macro directory.
borrisl
Post by borrisl »
Wow, that's easy. Too easy. Guess that's why I missed that part. Thanks for the quick reply.
I just saw that you use the Appimage. Please report if it works or not.
If you want to develop your own postprocessor it is a good idea to start with the linuxcnc because it is well serviced and widely used.
borrisl
Post by borrisl »
I'm going to be writing it for the Siemens 828 and Siemens 802.
moltenaluminium
Post by moltenaluminium »
Apologies for digging this post out of the grave, But @borresl did you ever finish your post processor and can you share it?
If you want someone to be notified, do it like this:
borrisl wrote: Sun Jun 10, 2018 11:35 pm ping
borrisl
Post by borrisl »
Still working on it. Had limited success and had to walk away. Back in the code saddle and writing them now.
Post by Kunda1 »
borrisl wrote: Mon Jul 04, 2022 7:25 am Still working on it. Had limited success and had to walk away. Back in the code saddle and writing them now.
Note: Snap edge (nightly) is also great for developing.
