Pocket operation cutting outside of area
Re: Pocket operation cutting outside of area
The model is broken, regardless of the elegance used to construct it.
Fix the model, and further explorations into any possible flaws in the Path workbench can become productive.
Gene
Gene
I agree that if the model is invalid then the Path workbench is just the messenger in this case and I'm certainly not arguing that Path should work with invalid models. But what's confusing to me is that I still can't see any issue with the model. Bear with me here, I'm not challenging anyone!
I just opened the model again (downloaded from this thread) and get no warning or error messages printed anywhere. Furthermore, I selected the root object ("bad_pocket_operation"), "Mark to recompute", then hit the Recompute button. Here's the result:
Note a few things. For starters, the path is now correct! I think someone else noted similar behavior earlier in this thread. I had previously recomputed the geometry and the path jobs but not the whole document. So that's the first question (although I suspect the answer is something in the geometry pipeline before it gets to the Path workbench...)
Secondly, there is no indication anything is wrong even after recomputing everything. No red exclamation points, no error messages in the report, no error messages in the console. Without knowing what's going on under the hood, it would seem to the average user (read: me) that nothing is actually wrong. Thus I would expect Path to work in this case and assume it's a bug in Path when it doesn't.
Do you guys actually get error messages or other indications the geometry isn't valid?
If I load the file and perform a recompute-all everything looks good, except that the last pocket shows an error. That means, that the view of the this pocket cannot be recomputed, so I see the old version. Going back one step things are completely different:
- Bildschirmfoto 2018-06-14 um 22.44.34.png (52.6 KiB) Viewed 1334 times
I see exactly the same error after a complete recompute that chrisb shows.
The difference may be related to the difference in FC versions. I am using an officially sanctioned pre-release version, and I believe chrisb is also using such a version.
Your version (hokieengr) is some sort of mash-up of old OCC and new Python, so this may be relevant.
Gene
Gene
Here is a proposal. It contains a master sketch which contains everything controlling the layout of the subsequent features. That makes it very robust. There is slightly too much in the master sketch, one rail would have been enough, I have modeled two because I didn't want to define half of the rail width.
Please try the Path generation, although I'm afraid after mlampert's find that it still will fail.
- PadAndPocketOnly.FCStd
- (60.73 KiB) Downloaded 57 times
Worked perfectly for me. Even the oddity at the crossover was gone.
OS: Windows 7
Version: 0.18.13959 (Git)
Hash: 2f18182b6dff87f8857787c854e39ca4d441f993
Python version: 2.7.14
OCC version: 7.2.0
Gene
OS: Windows 7
OCC version: 7.2.0
Gene
chrisb wrote: ↑Thu Jun 14, 2018 11:37 pmSadly still the same behavior as before. Even a full document recompute doesn't seem to fix it.
OS: Ubuntu 18.04 LTS
Version: 0.18.13905 (Git)
Build type: Debug
Hash: e80b5678ccfa59a5222b91bdc7e748a53a468468
Python version: 2.7.15rc1
OCC version: 6.9.1.oce-0.18
Thanks anyway for trying (but you still used the outdated version).
Sorry, I missed that you wanted me to try it with a different configuration. What would you like me to update?
In the meantime I rebuilt FC from the latest git master. Your file does cause an error (not sure if you expected that or not). See below:
You can see that I added the pocket operation again, recomputed everything, repeat, etc and same results as before. Note that I used "Offset" with a 50% set over. Zigzag works fine. Also, selecting the track face and running "Profile based on edges" results in the same straight line segment as the pocket.
I suspect this is the same issue as the one mlampert found.
Version: 0.18.13971 (Git)
Build type: Debug
Hash: 8e4dd8ca8496595d4718dc24c872f7ed668b2521
I currently get this message on every model I load which contains a Path Job. I will update and try again.
