New Chamfer op
New Chamfer op
If you have the experimental features enabled there is now an additional op called Chamfer. It allows you to select edges and/or faces and the op creates a chamfer Path for them, taking the tool shape into account. Currently Endmill (square) and Engraver (v-bit) are supported.
As an embarrassing detail, the op currently does not support selecting modeled chamfers for processing. If you add a face to the op it will chamfer all Edges of that face. Detection of modeled chamfer faces is an improvement still to come.
As always feedback is welcome, let me know what works and what doesn't.
- sliptonic
Re: New Chamfer op
Awesome feature! Great job.
Re: New Chamfer op
This is good addition!
Are inside edges supposed to be supported? At least on my first trial, this came out:
On the other hand, when selecting a face with both inside and outside features, both came out right. But, like you say, adding the chamfer to a face adds the cut on all edges, even the ones that are inside corners of a pocket, so selecting the face cannot be used in this case:
Re: New Chamfer op
Absolutely! For clarity, I removed other ops, only chamfers are there.
- mastbox.fcstd
- (854.41 KiB) Downloaded 51 times
Re: New Chamfer op
Oh boy, I just figured it out - the problem is that offsetting to the outside produces at least some paths that are not "inside the model" - specifically the two edges in Y direction so the algorithm considers it a valid solution. I guess it has to get smarter than that. If your short edges were sharp as well, there would be no overlap of the offset path with the model's solid.
This is a great test case - I'll add something like it to the unit tests!
Re: New Chamfer op
I was thinking about this a bit and was wondering what ppl think how the op should behave in a situation like this.
The op was asked to create a chamfer of 1mm - but two 2 of the 4 selected edges are not backed by enough material to support such a chamfer. In layman terms, the model isn't even 1mm thick.
I can see three options
1.) do as you're told and create the full path - which in this case would mean inside (more on that below)
2.) not generate any path if there isn't enough material for the requested chamfer
3.) only generate a path for edges backed by enough material to support a chamfer
About the inside vs. outside. I had always assumed it would be clear what is inside and what is outside, but clearly my mental model was to simplistic. Looking at roivai's model it is clear that the user could want a chamfer path on the inside OR on the outside of those selected edges. Only modifying the model slightly (reducing the width of the ridge at the top and bottom to 0 - same as the side walls) - and both sides make equal sense - or are equally likely to be intended.
So it seems if 1) is the way to go the op needs a "inside vs. outside" selector for the user to choose (which I was trying to avoid).
OTOH, if 2) or 3) are the way to go, one would not be able to use the Chamfer op to machine the slope, even if one had a tool bit with exactly that curved shape.
Thoughts? Opinions?
Thoughts? Opinions?
Re: New Chamfer op
I don't know how difficult it would be to figure out if the chamfer would be strange. If that can be done then I would suggest Option 4.) "I cannot do what you asked me to do. Choose Option 1, 2, or 3."
It is impossible for FreeCAD to know what the user wants to do. Any pre-determined solution will be "wrong" for some people.
Gene
Gene
Re: New Chamfer op
On first sight of roivai's model I was intrigued to say that 2 is the way to go. But it's allways similar with these auto thingies: In most cases they do what you need, but if not you simply cannot get around it. So I would vote for Gene's version 4, it's the luxury model, where you can e.g. select all edges and let them be chamfered, the system will ask back if there are problems.
If that's not an option I would vote for version 1: If the user doesn't want to chamfer a certain edge he simply deselcts it, so no restrictions from that side: it is possible to "not chamfer".
Here is a simple model showing that it can well be sensible to chamfer, even if there is not enough material. Furthermore it shows that it might be difficult to decide if there is enough material after all.
I have modeled the chamfer to better show what happens:
- chamfer.png (12.63 KiB) Viewed 2094 times
