I just tried 1mm on my work computer, but I don't see a crash here.
3d Pocket issue
Re: 3d Pocket issue
Can other Linux/Mac/Win users please test?
- sliptonic
Re: 3d Pocket issue
I get a path generated for most tool sizes (including larger than 5.0) but I also get the crash at 1.0
OS: Linux Mint 18 Sarah
Version: 0.18.14059 (Git)
Build type: Unknown
Hash: b54661c09a8a6c289a039d8d0848c08c165e2002
Python version: 2.7.12
OCC version: 7.1.0
Build type: Unknown
OCC version: 7.1.0
Re: 3d Pocket issue
Version: 0.18.14061 (Git)
Hash: c4fc02cbcfff975712e977dc08f859fba71ba0ad
Python version: 2.7.14
OCC version: 7.2.0
I get this error on loading the file:
No crash when setting tool diameter to 1.0, but I get an exception: Unknown C++ Exception.
I take it mode=0 is Absolute, mode=1 is BoundBox, mode=2 is Workplane in the area.makeSections() function below. Just by experimenting if I change mode=0 to mode=1 it seems the C++ exception doesn't happen with tool diameter set to 1.0 for the Pocket_3D operation and a path is formed.
PathAreaOp.py
Enumeration: AreaParams.h
This is also interesting. Perhaps by stepping through this bit of code the bug can be pinned down. I don't have a way to debug the C++ code at this time.
(at time of call from python, heights = [11.0,10.0,9.0,8.0,7.0])
Area.cpp
OCC version: 7.2.0
Enumeration index -1 is out of range, ignore it
<type 'exceptions.IOError'>: Cannot get value from invalid enumeration
PathAreaOp.py
def _buildPathArea(self, obj, baseobject, isHole, start, getsim):
'''_buildPathArea(obj, baseobject, isHole, start, getsim) ... internal function.'''
PathLog.track()
area = Path.Area()
area.setPlane(PathUtils.makeWorkplane(baseobject))
area.add(baseobject)
areaParams = self.areaOpAreaParams(obj, isHole)
heights = [i for i in self.depthparams]
PathLog.debug('depths: {}'.format(heights))
area.setParams(**areaParams)
obj.AreaParams = str(area.getParams())
PathLog.debug("Area with params: {}".format(area.getParams()))
sections = area.makeSections(mode=1, project=self.areaOpUseProjection(obj), heights=heights) #was mode=0
#define AREA_PARAMS_SECTION_EXTRA \
((enum,mode,SectionMode,2,"Section offset coordinate mode.\n"\
"'Absolute' means the absolute Z height (given in SectionOffset) to start slicing.\n"\
"'BoundBox' means relative Z height to the bounding box of all the children shape.\n"\
"'Workplane' means relative to workplane, minus SectionOffset.\n"\
"Note that OCC has trouble getting the minimum bounding box of some solids, particularly\n"\
"those with non-planar surface. It is recommended to use Workplane to specify the intended\n"\
"starting z height.\n",(Absolute)(BoundBox)(Workplane)))\
((bool,project,Project,false, "The section is produced by normal projecting the outline\n"\
"of all added shapes to the section plane, instead of slicing."))
Area.cpp
for(double z : _heights) {
switch(mode) {
case SectionModeAbsolute: {
gp_Pnt pt(0,0,z);
z = pt.Transformed(loc).Z(); /*could be here where the exception happens, maybe*/
break;
}case SectionModeBoundBox:
z = zMax - z;
break;
case SectionModeWorkplane:
z = -z;
break;
default:
throw Base::ValueError("invalid section mode");
