Settings for individual doglegs
We can currently turn on and off individual dogleg dressups but can we change the settings individually?
I think it would be great if we could do that. I currently have a part that needs two types (one to cut into a corner and one to extend a path and clean up an edge). They are both part of the same profile operation but require different methods.
- sliptonic
Re: Settings for individual doglegs
Yep.
Just double click the dogbone dressup and then enable/disable in the list
I don't think I was very clear. I was pointing out that we can currently turn them on and off, but can we adjust individual dogleg settings? For example, I want dogleg 1 to be Adaptive and dogleg 2 to be along the long edge.
Make sense?
Make sense?
I created an object similar to yours, settings:
Style: T-bone vertical
Side: Right
Incision: adaptive
When I uncheck one of the two corners I get an error:
File "/Users/cb/Desktop/FreeCAD.app/Contents/Mod/Path/PathScripts/PathDressupDogbone.py", line 921, in updateModel
self.getFields()
File "/Users/cb/Desktop/FreeCAD.app/Contents/Mod/Path/PathScripts/PathDressupDogbone.py", line 878, in getFields
self.obj.BoneBlacklist = sorted(blacklist)
AttributeError: Attribute (Name: BoneBlacklist) error: 'type in list must be int, not long'
Version: 0.18.13976 (Git)
Branch: (HEAD detached at fae0de5)
Hash: fae0de58581694157a97d567c151bdce75d387dc
Python version: 2.7.15
Qt version: 5.11.0
OCC version: 7.2.0
I get the message independent from the settings. File attached.
- dogbone.FCStd
- (18.92 KiB) Downloaded 38 times
- sliptonic
Yes. At this time you can't do that. All settings are for all dogbones. You'd have to create multiple dressups.
- sliptonic
I'm on git 14061 and can't duplicate the problem with your file. Can you try upgrading?
Hi sliptonic,
chris is on mac and there is 13976 the last version atm...
Gruß Herbert
No problems seen here.
OS: Windows 7
Version: 0.18.14090 (Git)
Hash: a7c8a4677f480f8733e700c3bd2cabc579e3e061
Python version: 2.7.14
OCC version: 7.2.0
I also went back and tried both 0.18.13971 and 0.18.13983, again with no problems.
Gene
OS: Windows 7
OCC version: 7.2.0
Gene
I will try later on my more current linux. What I had wanted to try was a test with multiple dressups - that is already answered by sliptonic.
