kreso-t wrote: ↑Fri Aug 24, 2018 7:31 pm
I think I fixed the problem with the py3 "No module named 'PathAdaptive'", haven't been able to test it myself with py3 (with py2 still works ok), but I'am pretty sure the problem is solved now and the reason was me not using "explicit imports" that py3 requires (i.e. https://stackoverflow.com/questions/121 ... nt-python3)
Nice!
VS2013/PY2/boost-python: builds, passes all Self-tests, and I can load the Path WB.
VS2015/PY3/pybind11: builds, I get the same Self-test errors I get in master, and the Path WB loads.
File "F:\MyFiles\FreeCAD_0.18.14442-kreso-t_Conda_Py3QT5-WinVS2016_x64\Mod\Path\PathScripts\PathAdaptive.py", line 143, in GenerateGCode
helixAngleRad = math.pi * obj.HelixAngle/180.0
<class 'TypeError'>: unsupported operand type(s) for /: 'Base.Quantity' and 'float'
However now using your py3 build I can test and correct those things and also check if there are some more similar problems
Thx
BR,
K.
This problem with "unsupported operand type(s) for /: 'Base.Quantity' and 'float'" is fixed now. I tested the full functionality using build FreeCAD_0.18.14442-kreso-t_Conda_Py3QT5-WinVS2016_x64 and did not find any more problems - with this fix (https://github.com/kreso-t/FreeCAD/comm ... 2ca8238b52) in the python script (....\PathScripts\PathAdaptive.py) the build seem to work OK.
This version in the FreeCAD_0.18.14442-kreso-t_Conda_Py3QT5-WinVS2016_x64 build also had a problem with a shapes like in the attached image:
when tool could not pass from one side to another due to too narrow regions in between (maybe also in some other cases but this is where I noticed it) so it cleared only one side of it (it skipped the other helix plunge), this is corrected now in the current FreeCAD fork version in my git repo.
kreso-t wrote: ↑Sun Aug 26, 2018 8:46 pm
This version in the FreeCAD_0.18.14442-kreso-t_Conda_Py3QT5-WinVS2016_x64 build also had a problem with a shapes like in the attached image: Selection_015.png when tool could not pass from one side to another due to too narrow regions in between (maybe also in some other cases but this is where I noticed it) so it cleared only one side of it (it skipped the other helix plunge), this is corrected now in the current FreeCAD fork version in my git repo.
BR,
Kreso
Hi Kreso,
I have come across an instance where a path isn't generated:
I would like to rough the outside of this part before profiling, however I cant get the adaptive tool to generate a path.
I would like to say a huge THANK YOU again. The adaptive toolpath is an absolute game changer for me. I haven't been able to use FreeCAD for CAM on most of my parts but the adaptive tool allows me to!!
BR,
Kreso
Hi Kreso,
Thanks,
Dan
Hi Dan,
Thx, it should be possible now with this most recent version (included in the forked FreeCAD https://github.com/FreeCAD/FreeCAD), btw. in this version you can also select edges, not only faces. In order for tool to be able to plunge into those relatively narrow area you need to limit the helix diameter (by default it takes tool diameter), however the python version that you seem to be using has one other problem that will prevent you to get the desired result here (it does not entirely correctly resolve the regions to cut even if you limit the helix diameter).
BR,
Kreso
Hi Kreso,
Thanks,
Dan
Hi Dan,
BR,
Kresimir
Hey,
Thanks for the super quick reply.
I will build your branch later and test.
Do you want feedback at the moment or is it too early?
would it be possible to have FreeCAD fork and https://github.com/kreso-t/FreeCAD_Mod_ ... e_Path-Cpp in sync? The latter is easy to build and use with freecad daily ppa. Hopefully Adaptive Path is soon part of the main branch repo of FreeCAD
Thanks,
Dan
Hi Dan,
Feedback would be very helpful. I have corrected the issues I noticed so far (in my FreeCAD fork version, I will sync that also to cpp add-on mod version, however I don't plan to further maintain the python version since I can't simply apply same fixes/features there without actually rewriting same stuff again in python), so if you find some more ploblems in this FC fork version please let me know so I can fix it.
schnebeck wrote: ↑Mon Aug 27, 2018 8:05 am
@kreso-t
Bye
Thorsten
Hi Thorsten,
I will see if I can sync it later today, however at the moment it is not possible to support some things without modifying the FreeCAD code which can't be done in add-on, so some features may not be available in this version (so far only this posibility to select edges).
