Adaptive Path/CAM Operation
mlampert
Re: Adaptive Path/CAM Operation
Postby mlampert » Fri Jan 04, 2019 10:19 pm
chrisb wrote:
Fri Jan 04, 2019 10:15 pm
Even if I recompute only the AdaptivePath the issue is toggled. It seems that not only the values of AdaptiveInputState and AdaptiveOutputState change, but also Placements of Z-axis, XZ plane.
I looked at the XY values, and it seems they are all over the place - suggesting that there might be a division by a very small value. Just a theory/hunch though.
schnebeck
Postby schnebeck » Fri Jan 04, 2019 10:31 pm
If I recompute Adaptive-OP in ChrisBs test file the result looks fine.
HTH
Thorsten
OS: Ubuntu 18.04.1 LTS
Version: 0.18.15521 (Git)
Hash: 6cdeab9c1469a41f24ae5e8fa9091c9bdfbb90db
Python version: 2.7.15rc1
Postby chrisb » Sat Jan 05, 2019 12:20 am
I wonder where it comes from. I tested on a Ubuntu installed on a virtual machine on my Mac. Outside the virtual machine I get the error, inside it is OK; so it's not a processor thing.
jurij
Postby jurij » Mon Jan 07, 2019 7:06 am
This is what I get with the cube model:
OS: Linux
Version: 0.18.15536 (Git) AppImage
Hash: 98ebeaa198df945ba666c15912c6caf95920f0ef
Python version: 2.7.6
Qt version: 4.8.6
Postby chrisb » Tue Jan 08, 2019 12:53 am
The error seems to come out of libarea.
            a2d = area.Adaptive2d()
            a2d.stepOverFactor = 0.01*obj.StepOver
            a2d.toolDiameter = float(op.tool.Diameter)
            a2d.helixRampDiameter =  helixDiameter
            a2d.keepToolDownDistRatio = keepToolDownRatio
            a2d.stockToLeave =float(obj.StockToLeave)
            a2d.tolerance = float(obj.Tolerance)
            a2d.forceInsideOut = obj.ForceInsideOut
            a2d.opType = opType
            #EXECUTE
            results = a2d.Execute(stockPath2d,path2d,progressFn)
Values going in a2d.Execute look good
One of result in results has the wrong values in result.AdaptivePaths
kreso-t
Postby kreso-t » Sat Jan 12, 2019 11:38 am
            a2d.opType = opType
            #EXECUTE
So the problem seem to be in the C++ code. As it does not seem to reproduce on Linux and Windows I am suspecting there is some difference in C++ compiler behaviour or STL implementation on Mac OS X environment. I don't have access to Mac (and also I don't have much experience with it) so it is difficult for me to find the cause of the problem. I can maybe try to borrow Mac for a few days but need to know first how to setup FreeCAD build environment on OS X. Do you know if there is some up to date tutorial about that?
Thx,
BR,
K.
Syres
Postby Syres » Sat Jan 12, 2019 1:56 pm
Sorry, I don't concur with the Windows platform being OK. If I load Chris' file running :
OS: Windows 7
Version: 0.18.15611 (Git)
Hash: 64a94ae0f7c60fc981086fe157150a9c0dca29c6
Python version: 3.6.6
Qt version: 5.6.2
I have the same fault. I just backspace the zero and one figures in the Tolerance field and re-enter them which produces the correct result.
Syres
Postby Syres » Sat Jan 12, 2019 2:04 pm
Apologies, ignore the above post, I realise it's OK after saving the corrected file on a Windows box but Chris always gets the fault even after re-saving on the Mac.
Postby chrisb » Sat Jan 12, 2019 4:10 pm
It's not a question of loading. Load the document an mark AdaptivePath (or the whole document) for recompute. After a recompute the problem vanishes on most computers.
Postby chrisb » Sat Jan 12, 2019 4:16 pm
mlampert had the same issue on Linux: https://forum.freecadweb.org/viewtopic. ... 10#p277776
The MacOS build process seems to be out of whack anyway. That's why we don't get regularly updates for MacOS .
I will send a MacMini to user looo, so he can work on it. Perhaps he can send the MacMini to you once he is finished. Where do you live?
