Flycutter Facing
dubstar-04
Flycutter Facing
Postby dubstar-04 » Mon Aug 27, 2018 5:57 am
I am trying to setup a facing operation using a flycutter, However I can't seem to get the tool path I would like (File attached).
This is the tool path using a 6mm Endmill:
Tool path using a 70mm diameter flycutter:
Tool Library:
What I would like is the tool to lead in from the y direction and move across the part in a single move. I'm guessing that I am having trouble as the tool is a larger diameter than the part width?
FreeCAD Info:
OS: Ubuntu 18.04.1 LTS
Version: 0.18.14016 (Git)
Build type: None
Hash: 5f63f9f23f10640b613cd894ed529eaf69a04aec
Python version: 2.7.14
OCC version: 7.2.0
TortureTest2.FCStd
(658.88 KiB) Downloaded 15 times
mlampert
Re: Flycutter Facing
Postby mlampert » Mon Aug 27, 2018 4:42 pm
That's correct, PathArea doesn't generate a Path if the tool doesn't fit inside the area to be processed. Also, PathArea doesn't generate single sweeps, it needs to make a loop.
Edit: What you can do is make Stock bigger than the tool and use Stock as the boundary for MillFacing
dubstar-04
Postby dubstar-04 » Mon Aug 27, 2018 5:06 pm
Thanks for the reply. Changing the stock doesn't seem like a very elegant solution.
IMO this should just work like it does for smaller tools. I would of though that facing with a flycutter is pretty common practice.
Is it worth filing a bug for this?
cahlfors
Postby cahlfors » Mon Aug 27, 2018 6:27 pm
It is not a bug - just missing functionality. For now, we have to accept it. I think I have seen a feature request for that or something similar.
If redefining the stock is not a good solution for you, you could create a helper object instead. In this case, just a slab with the necessary width to let you generate a path for your flycutter. It will not generate the single pass you desire, but it will get the job done. It is the same issue with face mills.
FreeCAD-daily/Ubuntu or Mint
Mendel 3d-printer/pronterface
HeeksCAM
LinuxCNC
Optimum BF20L mill
mlampert
Postby mlampert » Mon Aug 27, 2018 7:01 pm
I wasn't aiming at elegant, my bar was as low as "is it possible". I agree about your comments and I think you should enter an issue as a feature request - so we don't forget about it.
dubstar-04
Postby dubstar-04 » Mon Aug 27, 2018 7:41 pm
Thanks for taking the time to reply. I understand your perspective, TBH coding single pass facing ops would be simple enough by hand so that would probably be my approach, while we have a nice UI and some amazing tools it would be nice if we could work to extend them to cover more use cases hence report here:
https://www.freecadweb.org/tracker/view.php?id=3570
Thanks,
Dan
mlampert
Postby mlampert » Mon Aug 27, 2018 8:38 pm
Thanks, that's great.
