LibLathe - Lathe Path Generation
dubstar-04
Re: LibLathe - Lathe Path Generation
Post by dubstar-04 »
Wsk8 wrote: Mon Nov 09, 2020 9:02 am Hello,
tried it, but failed. So i printed the file name and it seems "ToolBit" is passed as tool_string. Don't know there this comes come...
I hardcoded DCMT070204R into LL and then it worked :D
Path looks also good, except it doesn't create roughing passes.
mfg
That is correct, as mentioned above the tool name hack will only work with legacy tools.
Its strange LibLathe hasn't created roughing passes.
Did you have the roughing checkbox selected?
Could you share the file?
Thanks,
Dan
Wsk8
Post by Wsk8 »
Yes, it was checked. Played also a little bit around with settings, but nothing changed.
CNC_Lathe_Test.FCStd
(30.08 KiB) Downloaded 55 times
dubstar-04
Wsk8 wrote: Mon Nov 09, 2020 9:25 am Yes, it was checked. Played also a little bit around with settings, but nothing changed.
Seems to be working ok for me. Check you have the latest turning addon and liblathe versions.
There is currently a bug in liblathe that is exposed when the stock is the same size or smaller than the model.
To workaround the bug make sure the stock is bigger than the model + stepover * finishing passes.
Thanks,
Dan
Wsk8
Post by Wsk8 »
I pulled LL just a few hours ago.
(193.38 KiB) Downloaded 63 times
dubstar-04
Wsk8 wrote: Mon Nov 09, 2020 12:15 pm I pulled LL just a few hours ago.
Maybe try less passes?
Does anything get printed to the report view?
Thanks,
Dan
dubstar-04
There appears to be an issue with the model you attached.
The start depth is below the finish depth and the max radius is set to zero.
This could possibly happen when an operation in the job has become invalid e.g. the tool controller has been deleted.
If it happens again please let me know.
Thanks for reporting it.
Dan
blue0cean
Post by blue0cean »
Lib Lathe is on the way up Congratulations. I tried a simulation on Linuxcnc today and I noticed that when generating G code in my version a Y-axis is generated in the output. Can I set something else here in the processor?
Secondly, I get a G-Code with a negative X axis. I have already looked here in the job setup but did not find anything corresponding. Can you please help me with the settings?
OS: Windows 10 (10.0)
Version: 0.19.22960 (Git)
Hash: c5a4b01d2e4218bcc0eb6650337650a6c65ef0e4
Python version: 3.6.8
Qt version: 5.12.1
DownloadsLL_TestJob.7z
(1.49 KiB) Downloaded 75 times
LL_Test.FCStd
(30.93 KiB) Downloaded 53 times
dubstar-04
Thanks for testing the turning add-on and thank you for your feedback.
blue0cean wrote: Thu Nov 12, 2020 7:59 pm I tried a simulation on Linuxcnc today and I noticed that when generating G code in my version a Y-axis is generated in the output. Can I set something else here in the processor?
There currently is no post process that is intended for lathe use and to be honest I haven't even tried it myself yet.
blue0cean wrote: Thu Nov 12, 2020 7:59 pm Secondly, I get a G-Code with a negative X axis. I have already looked here in the job setup but did not find anything corresponding. Can you please help me with the settings?
While it is on the todo list; LibLathe will currently only output -X coordinates, this is intention and will change as soon as I come close to testing on my machine.
There is still a lot of work to do with liblathe and the addon but with some encouragement and help with testing it will happen!
Thanks,
Dan
blue0cean
Post by blue0cean »
Thank you for your prompt reply. The superfluous Y coordinates can be quickly removed with an external editor to begin with. Inverting the X axis is a bit more difficult I think.
I am happy to support you in testing with a Linuxcncn machine.
GeneFC
Post by GeneFC »
blue0cean wrote: Thu Nov 12, 2020 8:32 pm Inverting the X axis is a bit more difficult I think.
Inverting the X axis is actually quite easy. I have done this a few times for milling operations.
Search and replace: "X-" >> "WW"
Search and replace "X" >> "X-"
Search and replace "WW" >> "X"
The only problem is that any comment containing an "x" may be mangled if this is done automatically.
Gene
