The horizontal Z-axis on the lathe strikes me as a local coordinate system that job models are translated to align. What is different about this compared to machining jobs that require aligning the model to face toward +Z?
LibLathe - Lathe Path Generation
Re: LibLathe - Lathe Path Generation
- sliptonic
conceptually there's nothing different. Almost all the milling operations assume Z+ is 'up' and that the spindle is aligned with it. The question that was posed here was about knowing the axis of rotation. I'm suggesting we can Assume it is around the Z axis and expect the user to align the model correctly. In other words it would be silly to have a property of a lathe job being 'axis of rotation' and the user selecting it.
Practically, the difference is that getting a model correctly aligned seems to be a real challenge sometimes. Try it and tell me if I'm wrong. The job setup tools need improvement to handle lathe orientations more smoothly
I agree. In concept, I would assume that any model would require alignment so it is aligned—and centered on—the z axis, in the job setup. As you mentioned, with user option to reverse between +/- z.
Broadly, most job models milled in Path are generated in FC, so in many cases, this isn’t an issue.
Agree that alignment of a general step model at an arbitrary translation sounds more complicated.
One thought—if the model at its existing translation is rotated around the z axis, it moves through minimal XY space when aligned.
Another thought—real lathes have a limited available cylindrical volume that the stock/model must be centered in. Doesn’t the assembly workbench provide this functionality?
- dubstar-04
Hi All,
I have made a PR https://github.com/FreeCAD/FreeCAD/pull/3951 to add some base features required for the turning functionality,
Once these changes are landed the turning operations should be available via this addon: https://github.com/dubstar-04/FreeCAD_Turning_Addon
With the addon installed the operations should be available via the Path Menu:
Note: The Turning functionality is nothing more than a proof of concept. The intention of releasing it as an addon is to encourage collaboration and testing to encourage development.
I could also add it to the Addon manager
- dubstar-04
That would be great! Does the addon manager resolve submodules?
I'd need to check. I'm thinking it doesn't but not certain.dubstar-04 wrote: ↑Sun Oct 11, 2020 10:42 am That would be great! Does the addon manager resolve submodules?
- dubstar-04
Ok great. If not I could split LibLathe and the Turning Operations into two separate addons.Kunda1 wrote: ↑Sun Oct 11, 2020 10:51 amI'd need to check. I'm thinking it doesn't but not certain.dubstar-04 wrote: ↑Sun Oct 11, 2020 10:42 am That would be great! Does the addon manager resolve submodules?
Longer term the plan is to have LibLathe as a separate addon anyway.
Thanks,
Dan
I checked the src/Mod/AddonManager/ source and it doesn't look like it pulls submodules. But I may be wrong.dubstar-04 wrote: ↑Sun Oct 11, 2020 10:55 am Ok great. If not I could split LibLathe and the Turning Operations into two separate addons.
+ I don't know about the new Extension Manager.
- dubstar-04
Post for discussion of PR to enable face selection for job setup.
https://github.com/FreeCAD/FreeCAD/pull/4003
Demo:
Demo:
